R can not be resolved
https://code.google.com/p/opendatakit.collect/
Eclipse IndigoEclipse Update Manager, just click Help → Software Updates in Eclipse. The Eclipse Update Site for MercurialEclipse is available at this URL:
http://cbes.javaforge.com/update
MercurialEclipse plugin
I tried import as Android Project from the Local Repository
Do not generate de autogenerated R file.
I clean,build also delete de R file(is not generated Again)
I tried Eclipse indigo,juno and differents workspaces.
Mercurial is not importing the whole project.
Please help.
Java 1.6
ODK default (1.2?)
Does it work for a basic Android hello world app? Do you have the
latest Android SDK and Eclipse integration? Are you sure the Collect
repo is being recognized as an Android project?
Try refreshing the project. Then close and re-open. Then clean and build.
If all fails, consider switching to IntelliJ. Seriously. Eclipse is miserable.
Please help.
Java 1.6
ODK default (1.2?)
You received this message because you are subscribed to the Google Groups "ODK Developers" group.
To unsubscribe from this group and stop receiving emails from it, send an email to opendatakit-developers+unsubscribe@googlegroups.com.
If you are new to Android development, work through the tutorial:
This will ensure your Eclipse and associated tools are set up correctly.
Then download and use ODK Collect.
NOTE: ODK Collect now requires the playservices project
http://code.google.com/p/opendatakit/source/browse?repo=playservices
miserable.
this URL:
Please help.
Java 1.6
ODK default (1.2?)
Also -- Sam notes that you are importing as an Android project. Try just
importing as an Existing Project into your workspace. That is what we do.
http://developer.android.com/training/basics/firstapp/index.html
miserable.
Please help.
Java 1.6
ODK default (1.2?)
