R code for downloading a form's submissions in Central using API
I'm trying to create an R script that will download all the submissions for a form from ODK central into a local zip file with the CSV and media attachments.
I am using the ruODK package and httr. However, with the code I've tried below, I can't see how to download the data. Any help would be useful.
ODK Central v1.1.2
>  x <- httr::RETRY("GET",
>                 paste0(ruODK::get_default_url(),
>                        "/v1/projects/",
>                        ruODK::get_default_pid(),
>                        "/forms/",
>                        "laLmRDT2",
>                        "/submissions.csv.zip?media=true"),
>                 httr::authenticate(Sys.getenv("ODKC_UN"),
>                                    Sys.getenv("ODKC_PW")
When this code is run I get the following message in the console window
Response [https:/xxx.xxx.xxx/laLmRDT2/submissions.csv.zip?media=true]
  Date: 2021-03-13 21:41
  Status: 200
  Content-Type: application/zip
<BINARY BODY>
The ODK Central API lets you download all the submissions for a form into a zip file with the CSV and media attachments. No external libraries required. I think you should be able to use the Central API URL and the base R function download.file as described here.
Exporting Form Submissions to CSV
To export all the Submission data associated with a Form, just add .csv.zip to the end of the listing URL. The response will be a ZIP file containing one or more CSV files, as well as all multimedia attachments associated with the included Submissions.
Hi @Lal_S,
This HTTP response indicates that you have received a binary file of mimetype "application/zip".
You are just missing the httr::write_disk argument to httr::RETRY/GET to actually save the file to disk instead of receiving the binary stream directly. See how ruODK does that here.
You should however not have to run httr::RETRY/GET yourself - the ruODK function to download submissions as zip archive (with or without nested tables or attachments - new!) submission_export does that for you.
See the submission_export examples and this vignette for more context and worked examples.
