Hi all,
I am implementing a household survey using ODK/SurveyCTO. I have a repeat
group which collects names and sexes of household members and would like to
randomly select the name of one boy from this repeat group. I have troubles
figuring out how to do it.
As explained here
https://groups.google.com/forum/#!msg/opendatakit/AkSq6VRSA_Y/Lt-RmBs33S8J,
without the condition that this person must be a boy this would be easy:
Just generate a random position of the repeat group and take the household
member at that position. But in my case, this person might be a girl and
repeating the procedure doesn't guarantee that the next time it will be a
boy.
Is there any way to do this? I have been trying to generate a new repeat
group with only the boys, but I haven't succeeded. The main problem for
this seems to be that I can not pass on information from one instance to
the next in a repeat group (from position(..) - 1 to position(..)). With
this, you could implement any "loop" to solve these kind of problems.
Thanks!
Wouter
Hi Wouter,
Here's a method that might work, though I'm not positive...
In your repeat, add an "isboy" field with a calculation like (modified to
test gender as appropriate to your gender field):
if(${gender}=1, 1, 0)
Also add a "boyname" field with a calculation like (modified again in the
same way):
if(${gender}=1, ${name}, '')
(Note that the second parameter to the if function is a pair of single
quotation marks.)
Now, outside the repeat you can have a "numboys" field with a calculation
like:
sum(${isboy})
And a "boynames" field with a calculation like:
join(' ', ${boyname})
(Note that the first parameter to the join function is a single space
inside single quotation marks. If you need to pull the boy's name from a
choice label, you'd call the jr:choice-name function in the above.)
So here you should have the number of boys and a list of their names. The
question is whether count-selected(${boynames}) returns the number of boys
or the total number of repeats. If the former, then you can use
random-once() and selected-at() to draw one of the boys; if the latter,
then this method won't work because the "boysnames" list still includes
entries (though blank) for the girls. If that's the case, then what we
really need is a way to collapse multiple spaces down to one (since, in the
space-separated list of names, there are multiple spaces for girls); post
back and we'll see if somebody else has an idea for how to do that. (We
might need to add a replace function of some sort... Such a need has come
up several times before.)
Chris
On Thu, Jan 2, 2014 at 3:21 AM, Wouter Gelade wrote:
Hi all,
As explained here
boy.
Thanks!
Wouter
Hello Chris,
Has anyone been able to come up with a solution to this?
currently in a form am designing, am able to pull out the choice list for
men who are at a certain age to respond to a certain question but this
comes with blank spaces for the women who have also taken up instance
spaces in the repeat group count.
Desperately need a solution, to be able to concatenate for men only without
the blank spaces.
Thanks!!!
On Thursday, January 2, 2014 at 12:46:17 PM UTC+1, Christopher Robert wrote:
> Hi Wouter,
> same way):
> quotation marks.)
> like:
> sum(${isboy})
> Best,
> Chris
> On Thu, Jan 2, 2014 at 3:21 AM, Wouter Gelade <wouter...@gmail.com > wrote:
>> Hi all,
>> As explained here
>> boy.
>> Thanks!
>> Wouter
>> "ODK Community" group.
