Ranking question
Dear ODK-community,
after having read through XLsform.org I still couldn't find out how to do create a priority/ranking question.
I would like to ask my interviewee to rank different answer-possibilities from one to three plus the opportunity to enter other answer-options.
Could you possibly help me with this problem?
Many thanks and kind regards,
Clara
Hi Clara,
The attached example lays out the framework for you to address this.
~Lloyd
Rank_example.xlsx (11.6 KB)
··· On Monday, June 27, 2016 at 1:12:34 PM UTC-4, clara....@googlemail.com wrote: > > Dear ODK-community, > > after having read through XLsform.org I still couldn't find out how to do > create a priority/ranking question. > I would like to ask my interviewee to rank different answer-possibilities > from one to three plus the opportunity to enter other answer-options. > > Could you possibly help me with this problem? > Many thanks and kind regards, > > Clara
I'm updating this post as it may be found by others seeking a similar solution. The ODK team came out with a new Ranking Widget that is great (and no longer needs the xlsxforms workaround). Details found HERE.
