1. What is the problem? Be very detailed. I deleted the form in the server my mistake and uploaded another one with changes unfortunately the enumerators in the field ended up using the form i deleted in the server kindly help me retrieve the data in their android devices
2. What app or server are you using and on what device and operating system? Include version numbers.(https://kc.kobotoolbox.org)
yes have tried to use ODK briefcase with java and i don't know were am messing up .Am not getting the results. Kindly i can even share a zoom link we discus it.
4. What steps can we take to reproduce the problem? quide me on how to go about it
5. Anything else we should know or have? If you have a test form or screenshots or logs, attach below. NO
Am trying and this what am getting back kindly help me out am supposed to give a report on the same tomorrow. I can still share an online link
you direct me further. Looking forward for your response
After copying the files to the computer, we are stuck at exporting, nothing happens for hours after hitting export. Please find attached the briefcase log
*2021-09-29 12:19:40,859 [ForkJoinPool-2-worker-1] WARN XFormParser - XForm Parse Warning: Warning: 1 Unrecognized attributes found in Element [model] and will be ignored: [xforms-version] *
