I am simply trying to reference a value from the internal dataset (from choices) as described in the documentation. However, my form fails to even load due to the error:
Error: ODK Validate Errors:
>> Something broke the parser. See above for a hint.
Error evaluating field 'pop_calc' (${pop_calc}[1]): The problem was located in Calculate expression for ${pop_calc}
XPath evaluation: Instance referenced by instance(states)/root/item/population does not exist
Caused by: org.javarosa.xpath.XPathMissingInstanceException: The problem was located in Calculate expression for ${pop_calc}
... 10 more
The following files failed validation:
${enketo_widgets}.xml
Result: Invalid
Clearly something is messed up with my form config, but I cannot figure out what it is since I basically just copied the example from the documentation.
enketo_widgets.xlsx (12.5 KB)
I am just testing the form out on https://getodk.org/xlsform/
I have tried various tweaks to the configuration (e.g. wrapping the whole calculation in string), but nothing has helped.
Use https://getodk.org/xlsform/ to convert a form that contains the configuration example from the internal dataset documentation.
Thanks!
