1. What is the issue?
I'm trying to limit number entry to integers (whole numbers) between, and including, 1-16. I believe this should work: regex(.,'^[1-9]$|^[1][0-6]$') if used in the constraints for an type=integer. It does correctly limit entries to 1-16, but, in webforms it still allows for decimals, like 1.2 or 12.6.
see screenshot for (4) below.
I've tested the regex and it should work per https://regex101.com/r/v3NaWw/1
