Is it possible to constrain a type int with regex? I need that the surveyor
enters with currency number like 9.999,99 (this is Brazil's currency
syntax). What is the regex syntax for this type of question?
I wouldn't use the integer or decimal prompts because they save to a
non-localized format (i.e., removes the period and comma). Use a
string prompt but with appearance="numbers".
Then you can use a regex lie "[\d]+.[\d]+,[\d]+" should work. Iterate
on it at http://rubular.com.
