Relevant columns
Hello,
I'm having difficulty with my skip logic. I'm not trying to do anything fancy but I can't get it to work. When I use the relevant column to code that some questions should only appear if the answer to a previous question = X, the questions are still appearing when the answer + Y if that makes sense. I'm not sure why I'm doing wrong. Here is the XLS I've built. Any help would be much appreciated!
rhd audit xlsform_V9.xlsx (23.2 KB)
Hello @Becci_ODK ,
I have taken a quick look at your form, your issue is capital letter in some wording, instead of "Relevant", use "relevant" as shown in this documentation https://xlsform.org/en/#relevant. This should solve your issue.
This is also the same for the name field, use same letter case when you refer to a certain value.
Thanks.
