I want to know the code to type in relevant that will give me the chance to skip a question when some number of choices are selected.
If you are authoring your form in a spreadsheet using the XLSForm syntax, you can use a relevant
column as described here in the documentation.
Hi @danbjoseph,
I have the same question, and I'm afraid I don't understand what syntax to use with just the number - or range as OP mentioned - of selections. The documentation gives examples of specific selections, such as:
selected(${favorite_topping}, ‘cheese’)
Whereas, what I feel @simondonkoh I are asking is if the syntax for the number of selections could be:
selected(${favorite_topping}, >= 2)
if at least 2 toppings were selected.
Thank you for your expertise!
EDIT: Maybe use 'count-selected(.)<=2' somehow?
I think I found at least some of the answer you need, based on something @yanokwa wrote some time ago:
count-selected(${your-variable-name} >= 2
I imagine you'd be able to indicate ranges by using:
count-selected(${your-variable-name} >= 2 and <=10
But I'm less sure about that last part!
Hi @simondonkoh and @awiggin,
You can try: (count-selected(${your-variable-name} >= 2) and (count-selected(${your-variable-name} <=10)
Hi @awiggin does his response answer your question? Also, welcome to the ODK forums. It'd be great if you could add a profile image and post an introduction to the community forum thread: Introduce yourself here!
And thanks @Souirji_Abdelghani! Also, you can format code in your post by wrapping a part of the text in single ` or by adding a line above with ```plain and below with just the three marks and no word "plain"
So it will display like this: (count-selected(${your-variable-name} >= 2)
or
Sometimes it can make it a little easier to read.
@danbjoseph and @Souirji_Abdelghani,
To be fair, it wasn't my question or my thread. I just jumped in to add some possibilities and more detail. I'll leave it to the OP (@simondonkoh) to make that call.
For my part, I figured my part out from info helpfully posted by @yanokwa a year ago - so thanks for having a good search function for the forums!
Many thanks!
Hi @danbjoseph,
Thanks for this useful information about formatting answers.
