Can anyone help me on this. How to make XlsForm Relevant syntax where the Third Question will appear if the First Question (select_one question) is the same as the answer to the Second Question (select_multiple question)
1- I would recommend to post this kind of issues in Support instead of Community
2- Because I do not know the whole context, this is an example. For the "same answer" I understood select multiple it is just one selection and equal to select one. Thats why I have included count-selected(${q2}) = 1.
The example was uploaded to ODK Sandbox for your testing.
Thanks Alexander_Torrado
