I need to force the interviewer to introduce information about the household in the first position. Something like:
What are the relationship between the respondent and the household. for the first postition in the repeat the option selected must be "1-Household".
Samsung Tab 2016 and Android 10.
I tried to use calculation variable to get a boolean valeu (selected${variable}, '1-Household')
Hi @Ayod_El_Modai_Arune ,
To reference a variable inside a repeat group you might want to use the function indexed-repeat(), which allows you to specify the position (e.g iteration).
I hope this helps.
Andrea
Hi @Andrea_Martin,
Can you show me the syntax, please? I didn't understand well the syntax of index-repeat() function.
I didn't cache it well in the documentation.
Ayod
The syntax is:
indexed-repeat(${question-name}, ${repeat-name}, index)
https://docs.getodk.org/form-repeats/#referencing-repeated-questions-from-outside-the-repeat
For example if you have a group ${roster}, and you are interested in the variable ${relation} for the first respondent (i.e. index==1), then you could create a calculate variable and in the calculation field enter:
indexed-repeat(${relation}, ${roster}, 1)
You can see another examples by searching similar questions in the forum, or at the link below in the Xlsx table, column calculate:
https://docs.getodk.org/form-repeats/#using-additional-repeats-to-follow-up-on-repeated-questions
I hope this helps!
Andrea
Hi @Andrea_Martin,
I just got the variable, even the boolean result. Even so I don't know where to use this calculated variable. Please check this file https://drive.google.com/file/d/1V4xpcYHWk0aaeUTlxG8AlAxQIaeR_l92/view?usp=sharing in the row 26. I need to tell ODK: Don't repeat if "relacao_c_chefe" is 0.
I think you have a couple of errors there:
- the calculated field at row 26 cannot perform the operation because the variable ${s1p3} is yet to be computed.
- also, the form supports entering more than one chefe
I would suggest a modification to the flow of your form.
A standard approach would be to collect information about the entire roster, starting from the chefe.
In this case you might want to skip question ${s1p3} for the first person and automatically assign the relation chefe. You could create an additional variable for this.
See example (_odkApp_iadcpc_AM.xlsx (117.3 KB) )
In the attached example I also pulled the name of the chefe from the top of the form, so you don't need to enter it again.
I hope this helps!
Andrea
Thanks @Andrea_Martin.
Now I begin understanding better how this stuff (indexa-repeat function) works.
All the best!
Glad to hear!
Good luck with your project @Ayod_El_Modai_Arune
Andrea
