Hello Community,
I need help with resolving a repeat group item in my XLSForm.
Example: If the user specifies 2, I want the next question to repeat twice
and accept entries 2 times.
I have something like this:
*type * *name *
label
repeat_count*
select_one LS_number q2a 2. How many owners who refused are available?
begin repeat repeat_group Owner Reason
select_one LS_reasons r1 2a. Why did the Owner refuse?
${q2a}
end repeat
I want Question 2a. to repeat based on the answer provided for Question 2.
But ODK allows you to add more Groups at 2a. until you choose "Do not add".
Thank you,
Bryan
You can use repeat_count (look for the column in the xlsform template).
On Monday, January 23, 2017 at 10:03:47 PM UTC+7, Test Isolate wrote:
> Hello Community,
> Example: If the user specifies 2, I want the next question to repeat twice and accept entries 2 times.
> type name label repeat_count
> select_one
> LS_number
> q2a
> are available?
> begin repeat
> repeat_group
> Owner Reason
> r1
> 2a. Why did the Owner refuse? ${q2a}
> end repeat
> Thank you,
> Bryan
https://lh3.googleusercontent.com/-3dDaj0wDqao/WIhwcd_0_CI/AAAAAAAAAAQ/zoKwFCt0SgMUtctqDJ9nQTjl1mvYx-QEACLcB/s1600/Screenshot_2017-01-25-09-27-54%255B1%255D.png
https://lh3.googleusercontent.com/-VndzoB9xkWs/WIhwVM6htzI/AAAAAAAAAAM/9Woc7YbD5ZgSSV6b5EOnCG6KzZ8dr4V_gCLcB/s1600/Screenshot_2017-01-25-09-28-07%255B1%255D.png
Thank you, Anonymous Helper!
When I check the xlsform page on repeats ( http://xlsform.org/#repeats )
and implement the
concept there; I still get an error. Please see screenshot attached.
I'm not sure if it's because I made the question that initiates the repeat
group [select_one] type instead of an [integer] type..???
Thank you,
Bryan
(Ghana-West Africa)
> > Hello Community,
> > type
> name
> label
> repeat_count
> > select_one
> > LS_number
> > q2a
> > are available?
> > begin repeat
> > repeat_group
> > Owner Reason
> > r1
> ${q2a}
> > end repeat
> 2.
> add".
> > Thank you,
> > Bryan
Likely the question 2 results in a non-integer and positive (perhaps it's a
text) number so that it violates the repeat_count.
LE DANG TRUNG, PhD
Chief Economist
[image: rta_logo]
Real-Time AnalyticsA: 1101, 11th Fl, Citilight Tower, 45 Vo Thi Sau,
District 1, HCMC
T: +84 8 6684 6530
M: +84 979 344 227
E: trungle@rta.vn thule@rta.vn
W: www.rta.vn
Disclaimer:
This message is private and confidential. If you have received this
message in error, please notify us and remove it from your system. Any
views or opinions presented here may be those of the originator and are not
necessarily those of Real-Time Analytics.
and implement the
Thank you,
Bryan
(Ghana-West Africa)
Hello Community,
type
name label
repeat_count
select_one
LS_number
q2a
are available?
begin repeat
repeat_group
Owner Reason
r1
${q2a}
end repeat
add".
Thank you,
Bryan
Thak you, Sir. Le Dang!
The question 2 are listed options and references the numbers from the
[choices] sheet. Where the [name] are
represented in number formats....Like: 1 2 3 4 5
Do I have to change question 2 from the [select_one] type to probably
[integer] ???
Can you please just give an example. I searched the entire group and
seems not to get it,
Thank you,
Bryan
(Ghana-West Africa)
> a text) number so that it violates the repeat_count.
> *LE DANG TRUNG, PhD*
> Chief Economist
> [image: rta_logo]
> *Real-Time Analytics*A: 1101, 11th Fl, Citilight Tower, 45 Vo Thi Sau,
> District 1, HCMC
> T: +84 8 6684 6530
> M: +84 979 344 227
> E: tru...@rta.vn
> W: www.rta.vn
> *Disclaimer:*
> *This message is private and confidential. If you have received this
> necessarily those of Real-Time Analytics.*
>> and implement the
>> repeat group [select_one] type instead of an [integer] type..???
>> Thank you,
>> Bryan
>> (Ghana-West Africa)
>>> > Hello Community,
>>> > type
>>> name
>>> label
>>> repeat_count
>>> > select_one
>>> > LS_number
>>> > q2a
>>> > are available?
>>> > begin repeat
>>> > repeat_group
>>> > Owner Reason
>>> > r1
>>> ${q2a}
>>> > end repeat
>>> Question 2.
>>> add".
>>> > Thank you,
>>> > Bryan
No need to change the question type, just force the value type to int() in
the repeat_count column:
int(${q2a})
Jason
> [integer] ???
> *Can you please just give an example*. I searched the entire group and
> seems not to get it, :)
> Thank you,
> Bryan
> (Ghana-West Africa)
>> Chief Economist
>> [image: rta_logo]
>> District 1, HCMC
>> T: +84 8 6684 6530
>> M: +84 979 344 227
>> E: tru...@rta.vn
>> W: www.rta.vn
>> *Disclaimer:*
>>> ) and implement the
>>> Thank you,
>>> Bryan
>>> (Ghana-West Africa)
>>>> > Hello Community,
>>>> > type
>>>> name
>>>> label
>>>> repeat_count
>>>> > select_one
>>>> > LS_number
>>>> > q2a
>>>> > are available?
>>>> > begin repeat
>>>> > repeat_group
>>>> > Owner Reason
>>>> > r1
>>>> ${q2a}
>>>> > end repeat
>>>> Question 2.
>>>> add".
>>>> > Thank you,
>>>> > Bryan
Hello Jason,
You are the BEST!! It worked and you are AWESOME!!
Thank you so so much, man.
Cheers!
Bryan
> int(${q2a})
> Jason
>> [integer] ???
>> Thank you,
>> Bryan
>> (Ghana-West Africa)
>>> it's a text) number so that it violates the repeat_count.
>>> Chief Economist
>>> [image: rta_logo]
>>> District 1, HCMC
>>> T: +84 8 6684 6530
>>> M: +84 979 344 227
>>> E: tru...@rta.vn
>>> W: www.rta.vn
>>> *Disclaimer:*
>>>> ) and implement the
>>>> Thank you,
>>>> Bryan
>>>> (Ghana-West Africa)
>>>>> template).
>>>>> > Hello Community,
>>>>> > type
>>>>> name
>>>>> label
>>>>> repeat_count
>>>>> > select_one
>>>>> > LS_number
>>>>> > q2a
>>>>> > are available?
>>>>> > begin repeat
>>>>> > repeat_group
>>>>> > Owner Reason
>>>>> > r1
>>>>> ${q2a}
>>>>> > end repeat
>>>>> Question 2.
>>>>> not add".
>>>>> > Thank you,
>>>>> > Bryan
