Repeat function
I want to repeat a set of question based on the answer of a previous question:
  • Repeat only once if the anwser to the previous question is option 1
    Repeat many times if the answer to the previous question is option 2 (repeat till the user stops)
    I am using ODK V1.30.1 with android version 10. I am using kobotoolbox server.
I visited the forum website and I downloaded ODK documentation.
I am quite new in ODK.
Hi @i_ousmane
We're glad you're here. When you get a chance, please introduce yourself on this forum thread. I'd also encourage you to add a real picture as your avatar because it helps build community!
You can solve this issue by having two groups, one with specified repeat_count = 1 and one without. Of course, only one group should be displayed depending on the previous question.
It could be something like:
repeatCountTest.xlsx (8.1 KB)
It helps me a lot. My problem is now solved.
Thank you very much.
