1. What is the problem?
I am using a form that has this feature: https://docs.getodk.org/form-logic/#repeating-as-long-as-a-condition-is-met
My use-case is that I don't know in advance how many repeats are needed and the enumerator may not know when they start the form and I've had lots of questions over the years about 'Add group' so wanted to avoid using this method...
I have just noticed that the jump menu does not show the symbols for add / remove a repeat. It appears that I can only navigate up, so in order to add another repeat I need to go to the end of the form, move back a question (Are there any more...) then select Yes. This is even more clumsy than the pop up!
I can't find a way of deleting a repeat in this form either.
This is not what I expected, but is it a consequence of using this method to avoid the 'Add group?' pop up?
ODK Collect 2012.1.2.4
Looked in the documentation for any indication that these features might not be compatible
Create a form using the example in the docs.
This is what it looks like in the jump menu screen... I am used to seeing a + button and the 'bin' to delete repeated groups.
