I have a survey in which there are 6 Livestock species of interest.
The first thing I want to do is ask farmers what veterinary drugs they have used in past 12 months.
Secondly for each drug used in last 12 months, I would like to ask which of the 6 Livestock species was treated.
Ps. Single drug may be used in treatment of more than one Livestock species.
Thirdly for each drug used per animal species, I want to know a set of following questions e.g
- How many times drug used to treat animal species
- To drug expenditure
- Did drug ever fail?
- What did Farmer do when drug failed?
Therefore if for example is drug A1 is used to treat Cattle, sheep, Poultry then Q1/Q4 is repeated for the 3 animal species for that drug.
I am programming in xls, using ODK Collect v 1.12.2
