Repeat Groups Calculations
Hello,
I am trying to limit the total percent of a repeat group(3 repeats) where the total percentage should not to be more than 100%.Unfortunately the total is not updating as intended . I have attached the syntax the repeat group. Please help
repeat_test.xlsx (8.8 KB)
Hi @kimanikihiu
you have to move ${lhz_total} out of the repeat_group: repeat_test.xlsx (6.0 KB)
Thanks @Grzesiek2010
Its working now.
Hello @Grzesiek2010.
I have just run in to another problem. When I put a value like 51 as the first percentage value I get a constraint message that the value is not allowed. However if I enter 50 the value is accepted . I am suspecting that "${lhz_total} + . <=100" is doubling the value or what could be wrong. Thanks
I finally solved it. the solution is to remove '+ .'
