I have a form that I want to use a repeat in but I want the label of each
repeat to be the value of that index entry in a choice. Is this possible
and if so, can someone give me an example?
For example:
type name label
geopoint Location Location
dateTime ReportDate Date Of Inspection
select_one types Type Damage Cause
select_one waterdepth WaterDepth Water Depth
begin repeat DamageRepeat
select_one damagetype Damage ${bldgsegment[repeat_count]}
end repeat
choices worksheet
bldgsegment 1 Foundation
bldgsegment 2 Superstructure
bldgsegment 3 Roofing
bldgsegment 4 Exterior Finish
bldgsegment 5 Interior Finish
bldgsegment 6 Doors/Windows
damagetype None None
So I want the form to look something like this:
Foundation
- None
- Affected
- Minor
- Major
- Destroyed
Superstructure
- None
- Affected
- Minor
- Major
- Destroyed
Doors/Windows
- None
- Affected
- Minor
- Major
- Destroyed
Priscilla,
The easiest thing to do is to ask what type of building segment you
have as the first question of the repeat and then use that response as
a label for the next questions.
You can then use jr:choice-name (more at
https://opendatakit.org/help/form-design/binding/) to output the
correct choice label, given the choice selection.
If you want to use repeat indexing somehow, position(..) will give you
the count of the repeat.
> For example:
> type name label
> end repeat
> choices worksheet
> Foundation
> None
> Affected
> Minor
> Major
> Destroyed
> Superstructure
> None
> Affected
> Minor
> Major
> Destroyed
> Doors/Windows
> None
> Affected
> Minor
> Major
> Destroyed
> "ODK Developers" group.
> email to opendatakit-developers+unsubscribe@googlegroups.com.
