I have repeat group for all hh member asking about their name , age , and other info , then later in another section i want to repeat and ask every member of the hh who their age above 5 question about education but i couldn't manage that. please see aTEST.xls (40.5 KB) ttached
Hi @Luat
We're glad you're here. When you get a chance, please introduce yourself on this forum thread. I'd also encourage you to add a real picture as your avatar because it helps build community!
You need to use the indexed-repeat
function to get values from another repeat group. You can read more about it here https://docs.getodk.org/form-repeats/
Generally it would look like: TEST.xls (11 KB)
I removed a lot to make that for a clear sample but what I changed is in yellow.
Thank you very much @Grzesiek2010 , but while i am trying this message appear ([row : 16] Missing calculation.)
Could you please make changes on the file attached without deleting any questions (specially Question: A27.
Appreciate your support TEST.xls (43 KB)
In that row 16 you have indexed-repeat(${A101}, ${hh_roster}, position(..))
in label
column but it should be in calculation
Hi @Luat,
Please take a look at this thread
Many Thanks
Thank you for your support, i am working on a big survey your support is highly appreciate.
I have another section, it gave me error when i put in relevant column : indexed-repeat(${Agender}=2, ${Aage}>11 and ${Aage}<50, ${Amarriage}=1, ${hh_roster}, position(..))
My condition is to repeat from hh roaster and should be only for age between 12 and 49, female, and married.
Thank you again.
You can't use the repeat-indexed function like that. The whole function returns a value for a given question on a given position in a given group
So for example this indexed-repeat(${A101}, ${hh_roster}, position(..))
retuns 20.
What you need is rather something like:
indexed-repeat(${A101}, ${hh_roster}, position(..))>11 and indexed-repeat(${A101}, ${hh_roster}, position(..))<50
I don't know what that ${Amarriage} means because you didn't attach the form.
Thank you very much it's working now,
