I'm using a modified version of ODK, and original javarosa library and I'm having some problems using repeatable (loop) group, with and without calculated fields in and across repeatable groups. In every cases after a random numbers of repetitions the next repetition does not appear, instead of the new one, the previous repetition appears in viewing mode and it is not possible to go on. I tried to put a delay before the call of the next repetition but it works sometimes.
Did someone know, if this is a known issue or have a solution?
Fixing issues like this are exactly why we are continually releasing
updates to our software.
If you are maintaining your own version of ODK, you will either need to
maintain your software changes in parallel with ours, or troll the list of
checkins and our release notes ( http://code.google.com/p/opendatakit/wiki/CollectReleaseNotes ) to see if
we fixed anything that might have impacted you.
As always, if you have a custom feature that is of value to the wider
community, and you want to contribute it back to the community under an
Apache 2 license, you are encouraged to do so. Then you won't be
maintaining as much divergent code, and it will be easier to keep your
custom fork in sync with the main software branch.
The ODK 2.0 tools will have a mechanism to create branded apps that utilize
the underlying common framework code so that there will be less need for
cloning the code trees of the core apps to isolate and brand your apps.
