Request Body too Large when trying to assign App Users
We have a large number of app users and when we try to add assignments we raise an error that says ‘Request Body too Large’. When we remove an assignment and then add another app user assignment it works, but if we try to increase the total number of assignments without removing one, we generate the error. It appears that we have hit an internal limit on the number of app user assignments, but I cannot find documentation on this limit.
My best guess is that this error can be reproduced by sending a PUT request with a payload size greater than 256000 bytes (our network traffic shows that incrementing the user pushes the request size over 256kb and then it fails.)
I have tried to find more detailed log info on the server, but the best error message we can find is in the network traffic ({"message":"Request body too large.","code":400.36})
Using that error code, we can see that the lines of code raising this error could be in three locations:
/usr/odk/test/integration/other/body-parser.js:24: code: 400.36,
/usr/odk/test/integration/api/entities.js:3982: code: 400.36,
/usr/odk/lib/util/problem.js:139: requestTooLarge: problem(400.36, () => 'Request body too large.')
Has anyone dealt with this issue before. I am still wondering if this is an configuration issue, or a internal limit. Any advice would be welcome!
Thank you!
Forgot to add the server version: server (v2025.2.1)
Is it possible the limit you’re hitting is 250kb? It seems very close to the request body size limit set at https://github.com/getodk/central-backend/blob/1b27a5fc28be999abcefc9eae7b0c92fdc35b1ab/lib/http/service.js#L32
That is very possible and this seems to be the issue we are seeing. For now we are temporarily removing users to add new ones to keep the payload under the limit.
I’m glad you have a workaround, but it doesn’t seem ideal!
Would using more specific APIs be an alternative option? I guess the following might be relevant:
