It doesn't work when I try from google...
So you can access directly here:
Can you give us a description of the Time Widget's purpose and action?
Interested,
☞§※☼:airplane:
~Neil
On Tue, Feb 22, 2011 at 11:29 AM, Aurelio wrote:It doesn't work when I try from google...
Issue 84: Time widget
http://code.google.com/p/opendatakit/issues/detail?id=84
I just added a timepicker. At the moment in the collect we have a
DatePicker.
I needed something like that but for the time (with default actual
hour and minutes) to save the start time or end time of a survey.
I also modified the aggregate to deal with the timewidget to save
HH:MM:SS to export in this format in excel.
Aurelio
On Feb 22, 5:51 pm, Neil Hendrick wrote: > Can you give us a description of the Time Widget's purpose and action? > Interested, > ☞§※☼✈☂☻ > ~Neil > > > > > > > > On Tue, Feb 22, 2011 at 11:29 AM, Aurelio wrote: > > It doesn't work when I try from google... > > So you can access directly here: > > >http://code.google.com/r/aurdipas-collect115/source/detail?r=27231639...Is this different than preloading start and end times from the javarosa
params?
Like this:
☞§※☼:airplane:
~Neil
On Wed, Feb 23, 2011 at 3:46 AM, Aurelio wrote:Issue 84: Time widget
http://code.google.com/p/opendatakit/issues/detail?id=84I just added a timepicker. At the moment in the collect we have a
DatePicker.
HH:MM:SS to export in this format in excel.Aurelio
Interested,
☞§※☼:airplane:
So you can access directly here:http://code.google.com/r/aurdipas-collect115/source/detail?r=27231639.
If you only use it for that no except on formatting... because you
will have like DD MM Day HH:MM:SS YYYY instead of only HH:MM:SS
Is a widget if you want to record a time.
Like the datepicker, you have the timepicker where you choose hour and
minutes....
Aurelio
