Good day,
(my apologies for the cross posting)
I am using ODK collect on Android and formhub.org to host my forms. I am
designing a pre screening form for our survey.
For a subject to be eligible to take part in the study they should meet all
the inclusion criteria, the inclusion criteria involves scoring above a
certain threshold (cut off score) and also not answering yes to one the the
questions in the pre screening tool.
what is the best way of designing the form? Use a conditional? if using the
conditional for the multiple select options, I am bit clear on how to
handle that, how do I handle the calculation?
See attached sample form.
In the form I would like to add all yes responses for the depression
screening group, anyone scoring 8 and above and not answering yes to ssq11
and meeting the inclusion and criteria should be enrolled.
Best and Regards
Ronald Munjoma
+263 775 625 283, +263 776 444 039
eligibility.xlsx (14.8 KB)
Ronald,
Add up all the counts from the questions to calculate the score. Then
make the questions for the actual study relevant based on that score.
See https://groups.google.com/d/msg/opendatakit/6xvJHi234i8/eeVdv_GYE2oJ
for an example.
On Sun, Jun 29, 2014 at 3:29 AM, ronald munjoma simbiso@gmail.com wrote:
Good day,
conditional for the multiple select options, I am bit clear on how to handle
Best and Regards
Ronald Munjoma
Yaw and Martijn,
Thank you for your assistance. I have tried the proposed solutions but
could not get it to work.
I have attached a section of the form of what I have tried to do.
Before administering the SSQ 14 I would like to evaluate if the client
meets the criteria. I need to replace: "Are you comfortable with us taking
you through the interview?" with something like:
- Not selected - NO for the inclusion questions
or
- Selected Yes for the inclusion questions
Then for the SSQ 14, I want to count the number of Yes responses.
Thanks and Regards
Ronald Munjoma
inclusion_exclusion.xls (60 KB)
On 29 June 2014 23:16, Martijn van de Rijdt wrote:
Hi Ronald,
One way of doing this is to create a calculated item for each question
that sets the value to 0 if no answer has been given and otherwise the
score according to your algorithm. The overall score will then simply be
the sum() of all these calculated items. While designing the form use notes
to output all the calculated values so you can check that they work
correctly. Be careful with sum() as it will result in NaN if one of the
values is empty.
You could also just create one long formula (without the other calculated
items) for the overall score but it will be harder to troubleshoot if it
doesn't work correctly.
The actual survey questions could be placed in one group that has a
relevant expression: ${overal_score} >= 8
Good luck!
On Sun, Jun 29, 2014 at 4:29 AM, ronald munjoma simbiso@gmail.com wrote:
Good day,
all the inclusion criteria, the inclusion criteria involves scoring above a
the conditional for the multiple select options, I am bit clear on how to
Best and Regards
Ronald Munjoma
"formhub-users" group.
email to formhub-users+unsubscribe@googlegroups.com.
Did you know that Enketo Smart Paper has now become the #1 tool for data
collection? Don't fall behind. Use it!
Enketo https://enketo.org | LinkedIn
http://www.linkedin.com/company/enketo-llc | GitHub
https://github.com/MartijnR | Twitter https://twitter.com/enketo
Best and Regards
Ronald Munjoma
+263 775 625 283, +263 776 444 309
Hi Ronald,
Please don't cross post to multiple lists.
In order increase the chance that someone will help, you'll need to
break down the problem into single issues and be very specific about
what is not working.
Let's start with counting responses. Build a simple two question form
and see if you can count the number of yes responses there. Try that
first and let us know how that goes (on one list).
If that doesn't work, attach the simple two question form you are
using and describe what doesn't work. The more detail you can provide,
the better.
On Thu, Aug 21, 2014 at 8:35 AM, ronald munjoma simbiso@gmail.com wrote:
Yaw and Martijn,
Thank you for your assistance. I have tried the proposed solutions but could
not get it to work.
or
Thanks and Regards
Ronald Munjoma
On 29 June 2014 23:16, Martijn van de Rijdt martijn@enketo.org wrote:
Hi Ronald,
that sets the value to 0 if no answer has been given and otherwise the score
according to your algorithm. The overall score will then simply be the sum()
of all these calculated items. While designing the form use notes to output
all the calculated values so you can check that they work correctly. Be
careful with sum() as it will result in NaN if one of the values is empty.
Good luck!
Good day,
Best and Regards
Ronald Munjoma
Enketo | LinkedIn | GitHub | Twitter
Best and Regards
Ronald Munjoma
Hi Ronald,
Nearly there!
For the ssqscore the formula should be in a 'calculation' column, not in
the relevant column. It should not include 'calculate='. See attached form.
It seems that casting an empty answer to number results in NaN (so the
score is only shown when all questions are answered). I think this is
correct behaviour. In your case you could probably just use ${ssq1} +
${ssq2} + ... etc to avoid this from happening.
Another tip, you could add the 'relevant' condition to the group ssq14_
instead of to all the individual questions.
When you're stuck with these kind of things Yaw's approach to divide the
problem into small pieces is the way to go. This tool is very useful too:
https://enketo.org/formtester especially in combination with the amazing
offline XLSForm convertor Nafundi has created and is linked to on
http://opendatakit.org/use/xlsform/. The formtester allows you to look
behind the scenes at the record in realtime, so you can see exactly what is
happening.
Cheers,
Martijn
inclusion_exclusion.xls (38 KB)
On Thu, Aug 21, 2014 at 9:35 AM, ronald munjoma wrote:
Yaw and Martijn,
or
Thanks and Regards
Ronald Munjoma
Hi Ronald,
values is empty.
Good luck!
Good day,
am designing a pre screening form for our survey.
Best and Regards
Ronald Munjoma
Groups "formhub-users" group.
an email to formhub-users+unsubscribe@googlegroups.com.
Best and Regards
Ronald Munjoma
Hi Yaw,
Thanks for your response.
Hi Ronald,
Noted.
As per your suggestion I have created a three question form (attached).
Following instructions in this thread:
https://groups.google.com/forum/#!searchin/opendatakit/calculation/opendatakit/R9pwelsmTlY/SwMTEm6_6zkJ
I am failing to display the SSQ 14 score. On enketo I am getting NaN as the
result, on ODK I am getting the note text only?
In my sheet a Yes =1 and No = 0
Thanks and Regards
Ronald Munjoma
the better.
Yaw and Martijn,
could
not get it to work.
taking
or
Thanks and Regards
Ronald Munjoma
Hi Ronald,
score
sum()
output
empty.
calculated
Good luck!
Good day,
am
above a
the the
to
ssq11
Best and Regards
Ronald Munjoma
Groups
an
Groups
an
Best and Regards
Ronald Munjoma
Best and Regards
Ronald Munjoma
Hi Martijn,
Hi Ronald,
Nearly there!
Thanks for the pointers, I realised the mistake earlier and changed but
still could note get it work, may be it was defned as 'calculate' type.
In thefinal form I will do it the suggested way.
I have started using this approach. I am now working on the selected and
not selected issue of the first part, if I get stuck I will post to the
list
This tool is very useful too: https://enketo.org/formtester
Thanks for the pointer to the formtester
especially in combination with the amazing offline XLSForm convertor
happening.
Thanks and Regards
Ronald Munjoma
On 22 August 2014 17:35, Martijn van de Rijdt wrote:
Cheers,
Martijn
On Thu, Aug 21, 2014 at 9:35 AM, ronald munjoma simbiso@gmail.com wrote:
Yaw and Martijn,
or
Thanks and Regards
Ronald Munjoma
Hi Ronald,
values is empty.
calculated items) for the overall score but it will be harder to
troubleshoot if it doesn't work correctly.
Good luck!
Good day,
Best and Regards
Ronald Munjoma
data collection? Don't fall behind. Use it!
Best and Regards
Ronald Munjoma
Best and Regards
Ronald Munjoma
