Is it possible to review an interview (using the 'Edit Saved Form' option)
on a different tablet to the one that collected the data?
I've tried copying the relevant blank form to /odk/forms, and the saved
form to the 'instances' directory, but the completed interview does not
appear.
In my opinion yeah...but tablet 2 needs to be exactly setup like tablet 1 -
in the ODK department that is. I have moved odk info from one phone to
another and it worked fine....
hope you get luck
appear.
"Like a camera I use the negative to develop..uDig"
"Success is the ability to go from one failure to another with no loss of
enthusiasm"
----------------------------------------------------------------------------------------------------------> OutSourceRox Roxroy K. Bollers
GIS & IT Service Provider
tel. 592.685.2737 ......................................................... Follow Us On Facebook http://www.facebook.com/OutSourceRox
Google+ https://plus.google.com/114064153117817313312
Twitter: @drbollershttp://www.twitter.com/drbollers
Alternatively, you can extend the external widgets functionality and
build an app to send files back and forth for review. Our team at
Nafundi built something similar a few years ago for NFC transfer and
it worked well.
> hope you get luck
>> Hi,
>> appear.
>> Thanks,
>> Thomas
>> "ODK Community" group.
>> email to opendatakit+unsubscribe@googlegroups.com.
> enthusiasm"
> OutSourceRox
> Roxroy K. Bollers
> tel. 592.685.2737
> Follow Us On
> Facebook
> Google+
> Twitter: @drbollers
Instead of NFC, we have built a tool utilizing wifi, which is more
available then NFC I believe (the tablets can set up wifi connections
themselves without a router). We can transfer both finalized and incomplete
instances, among others.
Trung.
On Thursday, February 5, 2015 at 9:07:24 PM UTC+7, Yaw Anokwa wrote:
> Hi Thomas,
> If you copy the entire /odk folder, it will work.
> it worked well.
> Yaw
> 1 -
> > hope you get luck
> > On 4 February 2015 at 19:47, Thomas Graydon-Guy <t.gray...@massey.ac.nz > wrote:
> >> Hi,
> option)
> >> appear.
> >> Thanks,
> >> Thomas
> >> Post: opend...@googlegroups.com
> >> Unsubscribe: opendatakit...@googlegroups.com
> Groups
> an
> >> email to opendatakit...@googlegroups.com .
> of
> > enthusiasm"
> > OutSourceRox
> > Roxroy K. Bollers
> > tel. 592.685.2737
> > Follow Us On
> > Facebook
> > Google+
> > Twitter: @drbollers
> Groups
> an
