I have a section of a survey which asks about plots of land and how they're being used. The respondent says they have x number of plots and then the form loops through a set of questions about each of them, including the size (area) of the plot in ares, what crops are grown on that plot, and the area of each crop. I can set a calculation for each crop to make sure it doesn't exceed the area of the plot and then another calculation at the end of the loop to make sure total crop area doesn't exceed the total plot area.
Ideally, I'd like the form to keep a running total of the crop area and notify the enumerator when the area of crops has exceeded the size of the plot. Any ideas how I might go about this? I'm currently building this form in Excel and then converting it to XML for upload into the CommCare platform. A sample Excel file of the above described loop is attached.
Thanks!
Justin
land_use_loop_example.xlsx (50.1 KB)
Hi Justin,
Ask on the CommCare list at https://groups.google.com/group/commcare-users.
Thanks!
Justin
