Hi All,
I am having trouble with using ODK briefcase to pull form instances off of
my samsung galaxy pocket's SD card. ODK collect saves the form instances to
the phone's internal storage, this is a problem for me as that space is
limiting and i would like to use the external sd that i put in the phone. I
tried manunally moving the odk file onto the sd card and using briefcase
but it says it is not a valid directory. If i just try to use briefcase
when the files are on the phone's internal storage i can pull the blank
forms but the form instances are not visible. How do i pull the form
instances using briefcase? Also, is there a way to tell ODK collect to save
all of its data to an external sd card instead of the phone's internal
storage. any help would be greatly appreciated!
Cheers,
Sarah
Sarah,
You should be able to pull directly from the phone's internal storage.
You should also be able to copy the /odk folder to the SD card or your
desktop computer and pull from there. What happens if you do the
latter and browse the instances folder on your computer. Do you see
completed forms there?
-- Need ODK services? http://nafundi.com provides form design, professional support, custom reporting, and software development for ODK.On Thu, Sep 12, 2013 at 11:21 AM, Sarah Pfeil skpfeil@gmail.com wrote:
Hi All,
tried manunally moving the odk file onto the sd card and using briefcase but
it says it is not a valid directory. If i just try to use briefcase when the
files are on the phone's internal storage i can pull the blank forms but the
form instances are not visible. How do i pull the form instances using
briefcase? Also, is there a way to tell ODK collect to save all of its data
to an external sd card instead of the phone's internal storage. any help
Cheers,
Sarah--
