Am working on a form that will need a search and select option. For example
search a District and from that District a list of Facilities should be
displayed only for that particular District so that the user can choose a
facility from the list. I was looking at sample "search and select form"
but it looks a bit complicated for me. Any way on hold I can solve this.
Hi Herald,
See http://xlsform.org/#cascade for an XLSForm example.
https://gumroad.com/l/odk-form-design-tips also has an example.
If you are coding in XML,
https://opendatakit.org/help/form-design/cascading-selects has an
example.
You can also search this mailing list for 'cascading selects' for even
more examples.
On Thu, Apr 6, 2017 at 7:44 AM, Herald Luwizghie wrote: > Am working on a form that will need a search and select option. For example > search a District and from that District a list of Facilities should be > displayed only for that particular District so that the user can choose a > facility from the list. I was looking at sample "search and select form" but > it looks a bit complicated for me. Any way on hold I can solve this. > > -- > -- > Post: opendatakit@googlegroups.com > Unsubscribe: opendatakit+unsubscribe@googlegroups.com > Options: http://groups.google.com/group/opendatakit?hl=en > > --- > You received this message because you are subscribed to the Google Groups > "ODK Community" group. > To unsubscribe from this group and stop receiving emails from it, send an > email to opendatakit+unsubscribe@googlegroups.com. > For more options, visit https://groups.google.com/d/optout.Thanks Yaw.
I forgot to reply you but it worked just as I wanted.
Thanks.
