Seeing form developer to build complex forms
(1) Project: The Strategic Impact Evaluation Fund at the World Bank is a multi-donor trust fund launched in March 2012 with support from the British government’s Department for International Development. The objective of the trust fund is: “to strengthen the design, implementation and use of results-focused monitoring and evaluation in order to improve the effectiveness of development policies in programs affecting human development outcomes.”
Along with a global consortium of organizations, SIEF is developing the Impact Data and Evidence Aggregation Library (IDEAL) to (i) publish and document RCT (Randomized Control Trial) data based on a set of schema and ii) consistently document effect sizes of different RCT-tested policies so that they can be used in evidence aggregation exercises.
SIEF is looking for a skilled and detail-oriented SurveyCTO Survey Programmer to join the IDEAL library project.
(2) Job description: survey design /maintenance + data analysis
The consultant’s main task will be programming multi-stage and complex SurveyCTO forms to register impact evaluation data extracted by coders from published RCTs and to check the accuracy and reliability. The consultant will also desk-test the forms to ensure they work correctly, edit the forms as instructed by the research team, and generate preliminary analyses of the data. The candidate should be a highly motivated person with experience in randomized controlled trials, data analyses, and survey programming using SurveyCTO and Open Data Kit.
(3) Scope:
The consultant will be hired as short-term consultant (STC), for 15 full-time-equivalent days of
work, contracted by the World Bank. We are looking to hire for this position as soon as possible and may extend the contract upon favorable performance!
If you are an interested candidate, please email your resume and a paragraph sharing your relevant experience via email jweech@berkeley.edu.
This topic was automatically closed after 90 days. New replies are no longer allowed.
