Hello Sir,
I need an urgent help as i have stuck in using repeat group.
Like i have a question where i am asking some information in repeat and then group like.
begin repeat a1
begin group info
name
age
end group
end repeat
calculate
in specifically calculate i want to count all the age which has been entered in the repeat where age was between 5-18.
Please suggest me how to do this.
Inside the repeat group, add a calculate row.
The calculation will be an if() function that returns 1 (if age between 5 and 18) or 0
if(${age} >= 5 and ${age} <= 18, 1, 0)
Then, outside the repeat group, use another calculate row get the sum() of that row.
sum(${age-count})
Does that make sense?
Thanking you so much sir,
Thanks for your instant and such insight reply..You really have saved my day........
