**1. I am designing a survey in
I have one select multiple question that have five option and I have follow up question for each option **
**2. I am using to https://build.getodk.org/ for survey development **
3. I have written the following code in /data/q1='option' on the show question if column
**4. I am Getting the follow up question whether I select the option or not I need to get the follow up question based on my selection. only
**5.
Hi @Lbashir
We're glad you're here. When you get a chance, please introduce yourself on this forum thread. I'd also encourage you to add a real picture as your avatar because it helps build community!
It's unclear what the problem is but I assume that your if condition doesn't work as expected? Could you attach your form?
thanks @Grzesiek2010 for coming back to me attached is my for my condition is not working around question number 22 which is multiple response and based question 22 and selection I want to display question 23 and 24SRS-EW-Form-version-1-export (1).xlsx (27.7 KB)
In xls we refer to questions using ${question_name} so for example you should use ${zone}='dollo' not /data/zone='dollo' (the second version is used in ODK Build that's the reason you expected the same format in xls probably, I mean it's also possible but let's say more difficult and error prone)
Please go through https://xlsform.org/en/
thanks for coming back the latter /data/zone='dollo' works also because my condition it do work in all select on chooses but it only doesn't work on this part /data/Theimpactofrainonwatersources='birka' and next five lines that follows I think it is because the question is Multiple response is there any other code for multiple response questions? for you information I am work on Build and exported the file from Build odk
The logic should be like: selected(/data/Theimpactofrainonwatersources, 'birka') but again I encourage you to use the short version selected(${Theimpactofrainonwatersources}, 'birka')
You can find more about relevant and selected function here https://xlsform.org/en/#relevant
