Select_one question is not showing data after saving
a select_one question is not showing when the data after i save it. If i go to edit the response is missing
odk collect 1.12.2
nothing
Can you share a demo version of the form you are working on? so that one of us can try to help you resolve the issue.
Imran
Hello ,
Yes as @A.N.M_AL-IMRAN has suggested please do share the sampke XLSForm . And i know this is silly but may i know , are you finalizing the form and saving it or incomplete form
@A.N.M_AL-IMRAN and @SGSC Here is the link to my xform. After completing the form and save then when i go to edit ,The variable GVH and FDP are showing blank field as if it was not answered.
I dug into this and there are two bugs in pyxform that are causing problems in Collect.
  1. If you have a space or special character (e.g., quote marks) as the name/value of a select option, pyxform should warn you. In this case, it's not warning you because there is a choice_filter. That's a bug.
  2. In the case where you don't have a choice_filter, pyxform does warn, but it should instead throw an error and prevent the creation of the XML because if you have a space the value won't be saved (which to me is data loss that a user may not notice).
I have filed the issue at https://github.com/XLSForm/pyxform/issues/175. As a workaround, please remove the spaces from the name column in your choices sheet.
