The present behavior for the drop-down select_one widget (select set to
minimal appearance) seems to confuse some of our users. With a minimal
appearance, the first option appears to some users either as a default
answer or a selected answer. When the another option using the default
settings, a colored indicator clearly shows whether any option has been
selected
Is there a way to display a text (i.e. "select one") instead of displaying
the first option for drop-down widgets, similar to "select answer" with
multiple select options?
selected
On Wed, Jul 4, 2012 at 5:14 PM, ゴー・ニコライ <nikolai.go@gmail.com<javascript:_e({}, 'cvml', 'nikolai.go@gmail.com');> wrote:
selected
displaying the first option for drop-down widgets, similar to "select
answer" with multiple select options?
