Hi Luke,
You might be able to avoid the errors by wrapping your formulas in ifs like
so:
if(count-selected( /test-form/Q1 ) > 0, selected-at( /test-form/Q1, 0), "")
Regards,
-Nathan
Thanks, Nathan, that seems to be working!
Luke
On Sunday, May 26, 2013 6:49:29 PM UTC-4, Nathan wrote: > > Hi Luke, > You might be able to avoid the errors by wrapping your formulas in ifs > like so: > if(count-selected( /test-form/Q1 ) > 0, selected-at( /test-form/Q1, 0), "") > Regards, > -Nathan > > On Saturday, May 25, 2013 11:58:36 AM UTC-7, Luke MacDonald wrote: >> >> I have a multiselect question (Q1) with 17 choices and would like to >> return the first selected value of that question in a calculate type (Q2). >> >> This should be possible using either selected-at() or substr(). However, >> I both cause ODK validate to fail using xlsform and ODK collect to crash if >> plugged into XML directly. >> >> I tried these three approaches: >> >> 1) > nodeset="/test-form/Q2" type="string"/> >> 2) > type="string"/> >> 3) > type="string"/> >> >> >> #1 causes ODK validate to fail with this error: >> java.lang.ArrayIndexOutOfBoundsException: 0 >= 0 >> >> #2 causes ODK validate to fail with this error >> java.lang.StringIndexOutOfBoundsException: String index out of range: 2 >> >> #3 returns the entire string, i.e. all answers selected in Q1 (as >> expected). Changing the starting position from 0 to 1, 2, 3, etc. also >> works as expected. >> >> I'm totally confused, because I think I am applying selected-at() and >> substr() in the straightforward shown on >> http://opendatakit.org/help/form-design/binding/ >> >> It seems that ODK validate is looking for Q1 to already exist (i.e. >> already be answered) in the case of #1 and #2, but doesn't care if Q1 >> exists yet in the case of #3. Adding a relevancy statement doesn't help: >> relevant =" /test-form/Q1 != '' " >> >>FYI, the substr() issue has been filed, with a proposed fix, at
https://code.google.com/p/opendatakit/issues/detail?id=832. We might need a
similar fix for selected-at(). These functions really ought to be usable
without complex surrounding if's.
Chris
On Mon, May 27, 2013 at 12:49 AM, Nathan wrote:Hi Luke,
like so:
Regards,
return the first selected value of that question in a calculate type (Q2).This should be possible using either selected-at() or substr(). However,
plugged into XML directly.I tried these three approaches:
#1 causes ODK validate to fail with this error: java.lang.**
ArrayIndexOutOfBoundsException**: 0 >= 0#2 causes ODK validate to fail with this error java.lang.**
StringIndexOutOfBoundsExceptio**n: String index out of range: 2#3 returns the entire string, i.e. all answers selected in Q1 (as
works as expected.I'm totally confused, because I think I am applying selected-at() and
substr() in the straightforward shown on http://opendatakit.org/help/**
form-design/binding/ http://opendatakit.org/help/form-design/binding/It seems that ODK validate is looking for Q1 to already exist (i.e.
relevant =" /test-form/Q1 != '' "--
Hello , is there a way of doing the same that Luke wants with .xcl 2 .xml
syntax?
any hint?
2013/5/29 Christopher RobertFYI, the substr() issue has been filed, with a proposed fix, at
a similar fix for selected-at(). These functions really ought to be usable
without complex surrounding if's.Chris
On Mon, May 27, 2013 at 12:49 AM, Nathan nabreit@gmail.com wrote:
Hi Luke,
like so:
Regards,
However, I both cause ODK validate to fail using xlsform and ODK collect
to crash if plugged into XML directly.I tried these three approaches:
Jorge Durand Zurdo
*joduzu@gmail.com
- joduzu@gmail.com*skype user: *joduzu
I'm not quite sure what you mean by .xcl 2 .xml syntax. If you mean XLSForm
syntax, the answer is yes, the same approach of wrapping formulas in "if"
functions works there too.
Regards,
-Nathan
On Wednesday, May 29, 2013 6:43:05 AM UTC-7, Jorge Durand Zurdo wrote: > > Hello , is there a way of doing the same that Luke wants with .xcl 2 .xml > syntax? > > any hint? > > Thanks > > > 2013/5/29 Christopher Robert <cro...@surveycto.com > > >> FYI, the substr() issue has been filed, with a proposed fix, at >> https://code.google.com/p/opendatakit/issues/detail?id=832. We might >> need a similar fix for selected-at(). These functions really ought to be >> usable without complex surrounding if's. >> >> Chris >> >> >> >> On Mon, May 27, 2013 at 12:49 AM, Nathan <nab...@gmail.com >wrote: >> >>> Hi Luke, >>> You might be able to avoid the errors by wrapping your formulas in ifs >>> like so: >>> if(count-selected( /test-form/Q1 ) > 0, selected-at( /test-form/Q1, 0), >>> "") >>> Regards, >>> -Nathan >>> >>> On Saturday, May 25, 2013 11:58:36 AM UTC-7, Luke MacDonald wrote: >>>> >>>> I have a multiselect question (Q1) with 17 choices and would like to >>>> return the first selected value of that question in a calculate type (Q2). >>>> >>>> This should be possible using either selected-at() or substr(). >>>> However, I both cause ODK validate to fail using xlsform and ODK collect >>>> to crash if plugged into XML directly. >>>> >>>> I tried these three approaches: >>>> >>>> 1) >>> nodeset="/test-form/Q2" type="string"/> >>>> 2) >>> nodeset="/test-form/Q2" type="string"/> >>>> 3) >>> type="string"/> >>>> >>>> >>>> #1 causes ODK validate to fail with this error: java.lang.** >>>> ArrayIndexOutOfBoundsException**: 0 >= 0 >>>> >>>> #2 causes ODK validate to fail with this error java.lang.** >>>> StringIndexOutOfBoundsExceptio**n: String index out of range: 2 >>>> >>>> #3 returns the entire string, i.e. all answers selected in Q1 (as >>>> expected). Changing the starting position from 0 to 1, 2, 3, etc. also >>>> works as expected. >>>> >>>> I'm totally confused, because I think I am applying selected-at() and >>>> substr() in the straightforward shown on http://opendatakit.org/help/** >>>> form-design/binding/ >>>> >>>> It seems that ODK validate is looking for Q1 to already exist (i.e. >>>> already be answered) in the case of #1 and #2, but doesn't care if Q1 >>>> exists yet in the case of #3. Adding a relevancy statement doesn't help: >>>> relevant =" /test-form/Q1 != '' " >>>> >>>> -- >>> -- >>> Post: opend...@googlegroups.com >>> Unsubscribe: opendatakit...@googlegroups.com >>> Options: http://groups.google.com/group/opendatakit?hl=en >>> >>> --- >>> You received this message because you are subscribed to the Google >>> Groups "ODK Community" group. >>> To unsubscribe from this group and stop receiving emails from it, send >>> an email to opendatakit...@googlegroups.com . >>> For more options, visit https://groups.google.com/groups/opt_out. >>> >>> >>> >> >> -- >> -- >> Post: opend...@googlegroups.com >> Unsubscribe: opendatakit...@googlegroups.com >> Options: http://groups.google.com/group/opendatakit?hl=en >> >> --- >> You received this message because you are subscribed to the Google Groups >> "ODK Community" group. >> To unsubscribe from this group and stop receiving emails from it, send an >> email to opendatakit...@googlegroups.com . >> For more options, visit https://groups.google.com/groups/opt_out. >> >> >> > > > > -- > > Jorge Durand Zurdo > *joduzu@gmail.com > * *skype user: **joduzu* > >Thanks Nathan , Yes that's what I meant, but I wonder under witch column
should I insert the "if(count-selected( /test-form/Q1 ) > 0, selected-at(
/test-form/Q1, 0), "")" relevant? calculation?
Best
Jorge
2013/5/29 NathanI'm not quite sure what you mean by .xcl 2 .xml syntax. If you mean
XLSForm syntax, the answer is yes, the same approach of wrapping formulas
in "if" functions works there too.
Regards,
-NathanOn Wednesday, May 29, 2013 6:43:05 AM UTC-7, Jorge Durand Zurdo wrote:
.xml syntax?any hint?
2013/5/29 Christopher Robert cro...@surveycto.com
https://code.google.com/p/**opendatakit/issues/detail?id=**832https://code.google.com/p/opendatakit/issues/detail?id=832.
We might need a similar fix for selected-at(). These functions really ought
to be usable without complex surrounding if's.Chris
On Mon, May 27, 2013 at 12:49 AM, Nathan nab...@gmail.com wrote:
Hi Luke,
like so:
if(count-selected( /test-form/**Q1 ) > 0, selected-at( /test-form/Q1,
0), "")
Regards,
ArrayIndexOutOfBoundsException: 0 >= 0#2 causes ODK validate to fail with this error java.lang.**
StringIndexOutOfBoundsException: String index out of range: 2#3 returns the entire string, i.e. all answers selected in Q1 (as
*fo**rm-design/binding/http://opendatakit.org/help/form-design/binding/It seems that ODK validate is looking for Q1 to already exist (i.e.
Unsubscribe: opendatakit...@**googlegroups.comOptions: http://groups.google.com/**group/opendatakit?hl=enhttp://groups.google.com/group/opendatakit?hl=en
an email to opendatakit...@**googlegroups.com.For more options, visit https://groups.google.com/**groups/opt_outhttps://groups.google.com/groups/opt_out
Jorge Durand Zurdo
*joduzu@gmail.com
**skype user: *joduzu--
Jorge Durand Zurdo
*joduzu@gmail.com
sorry I got it !!
2013/5/29 Jorge Durand ZurdoThanks Nathan , Yes that's what I meant, but I wonder under witch column
/test-form/Q1, 0), "")" relevant? calculation?Best
Jorge
2013/5/29 Nathan nabreit@gmail.com
Regards,
Hi Luke,
like so:
0), "")
Regards,
form-design/binding/http://opendatakit.org/help/form-design/binding/It seems that ODK validate is looking for Q1 to already exist (i.e.
Jorge Durand Zurdo
*joduzu@gmail.com
Jorge Durand Zurdo
*joduzu@gmail.com
Jorge Durand Zurdo
*joduzu@gmail.com
