We are planning to use ODK collect and aggregate for survey. What we expect is that our enumerator teams will collect the data from the field and our monitors will pick 5 to 10% random respondent to cross check the validity of the data. Now my question is that is there a way to send data back to monitor as filled form for verification.
Please suggest.
Looking forward.
Majid
When you say "send data back to monitor as filled form for verification." -
do you mean that you want the monitor will see the form as it appears in
ODK collect? Rather than to see the 'final' data as it would appear in
Aggregate?
I think that may be possible but it is probably a bit of a complex task for
what could be achieved just using Aggregate. Somehow selecting some
responses in aggregate and then sending them to ODK collect as incomplete
responses, so they can be viewed (and edited again)
That's the extent of my knowledge! I would probably stick with Aggregate
for monitoring.
Hi Majid,
For this sort of baseline and follow-up form filling, I find
preloading forms via CSV http://xlsform.org/#pre-loading-csv-data
works great and your follow up form can have as much or as little data
from the baseline form as you need.
> do you mean that you want the monitor will see the form as it appears in ODK
> Aggregate?
> That's the extent of my knowledge! I would probably stick with Aggregate for
> monitoring.
> "ODK Community" group.
Thanks for your response.My main objective is to verify that the enumerator has collected real information. For this purpose here is our workflow.
- Around 80 enumerators will collect information in different locations (Districts, Tehsils, Villages)2. We will take 5% random forms in one village for verification.3. One village will be assigned to one Monitor for verification.4. The Monitor will check each question in the form and verify if it is correct yes or no.5. Once the the verification data is with us we can calculate statistics, how many forms are fully/partially verified.
Now as per my understanding we can extract 5% data group by village, now how to put it into verification forms(same form with additional verification attributes) and send it back to specific Monitor.
I hope you got my workflow.Please suggest what step should I take to implement this workflow.
Thanks,Majid
Hi Majid,
Aggregate?
monitoring.
You received this message because you are subscribed to a topic in the Google Groups "ODK Community" group.
To unsubscribe from this topic, visit https://groups.google.com/d/topic/opendatakit/ZKawksITiZY/unsubscribe.
To unsubscribe from this group and all its topics, send an email to opendatakit+unsubscribe@googlegroups.com.
Hi Majid,
I stand by my earlier recommendation. The approach I'd take is as follows.
Collect the data normally, but be sure to include some unique
identifier for each participant. Of those results, take your 5% random
in each village.
To make the verification form, take the original form, and keep the
original questions, but add a verification question (select one,
yes/no) for each original question.
You can use CSV preloading (e.g.,
http://xlsform.org/#pre-loading-csv-data) to load the values for those
original questions. Make these values read-only.
In the CSV, include the unique identifier for the participant and a
unique identifier for the enumerator who is assigned to the
participant in the CSV. These two IDs can be used to look up the
original data and load the data into the verification form.
Have the verification enumerators download the verification form.
The verification form can then be used to check the values in the
original form and mark it correct (e.g., yes/no). Once the data is
submitted, you can just count the number of yes/no.
Try this process with a 2-3 question form and see how it feels.
> 1. Around 80 enumerators will collect information in different locations
> correct yes or no.
> Thanks,
> Majid
> Hi Majid,
> Yaw
>> ODK
>> Aggregate?
>> for
>> for
>> monitoring.
Oh, and as far as more automated ways to verify accuracy, we are
working on a feature at
https://github.com/opendatakit/collect/issues/257 that will collect
timing/location/audio data in the background.
On Fri, Apr 21, 2017 at 6:06 PM, Yaw Anokwa wrote:
> Hi Majid,
> 1. Collect the data normally, but be sure to include some unique
> in each village.
> 2. To make the verification form, take the original form, and keep the
> 3. You can use CSV preloading (e.g.,
> 4. In the CSV, include the unique identifier for the participant and a
> 5. Have the verification enumerators download the verification form.
> Yaw
>> correct yes or no.
>> Thanks,
>> Majid
>> Hi Majid,
>> Yaw
>>> ODK
>>> Aggregate?
>>> for
>>> for
>>> monitoring.
