Set default center of map and zoom level in form
Hello !
I have a question about maps: Is there a way to set default map extent by defining the center of the map and zoom level in the xlsform ? (in appearance ?)
The objective is to get map widget center on a territory. Not for having default value.
I read old issue on this topic but nothing looks done.
Thank you for answer,
Hi @PNPyrenees
This is not possible. I would recommend creating a feature request in https://forum.getodk.org/c/ideas/9 and explaining why adding those options would be helpful.
@PNPyrenees - I'm not sure if you've seen the discussion around remembering the last zoom level. We are thinking this functionality will come later in our roadmap.
It doesn't sound like that will completely solve the problem, but I'm curious to know if that would help or not. And as @Grzesiek2010 mentioned, learning a bit more about your workflow and why it would be helpful will give us better context.
