I am repeatedly looping and collecting values. In practice, the first value
for most fields will be the same for subsequent iterations.
Is there a way that the previous entry for each field can become the new
default entry ?
I attach a minimal xls to illustrate this. I put ${breed} in default for
breed - unsurprisingly it does not work as I imagined it might.
Similarly with this form, the animals id is likely to be incremental, so I
could calculate a likely default by adding 1. How can I get that value and
make it the new default?
Thanks for help and patience with a newbie - I promise I am searching for
solutions before I ask here and I am making great progress
The example mention in the link is carrying forward the calculated tip in
note. Hope this helps
Abbas
> value for most fields will be the same for subsequent iterations.
> default entry ?
> I attach a minimal xls to illustrate this. I put *${breed}* in default
> for breed - unsurprisingly it does not work as I imagined it might.
> solutions before I ask here and I am making great progress :-)
That does work for label, but does not work if I put the variable into the
default field
Is there a way to put a variable into default? This must be a very common
requirement.
Steve
On Saturday, June 25, 2016 at 2:44:35 AM UTC+3, abba...@gmail.com wrote:
> Hi Steve,
> Please see calculation example here: http://xlsform.org/#calculation
> Thanks,
> Abbas
>> default entry ?
>> I could calculate a likely default by adding 1. How can I get that value
>> and make it the new default?
Could you explain in more what is your end goal - what you are trying to
achieve by putting variable as default in detail?
Thank,
Abbas
On Saturday, June 25, 2016 at 12:46:17 PM UTC+5, steve kemp wrote:
> Thanks
> default field
> common requirement.
> Steve
>> Hi Steve,
>> Thanks,
>> Abbas
>>> default entry ?
>>> for solutions before I ask here and I am making great progress :-)
The xls i attached was an attempt to explain what I was trying to do.
I am collecting data on animals that will usually come through in batches
with common characteristics. The form repeats collecting data on each. For
example, breed is collected on each. After I have recorded one animal, the
next is very likely to be the same breed and I would like the value entered
on the previous repeat to become the default on the next repeat. This would
dramatically speed-up data entry.
Thanks for your help
Steve
> Thank,
> Abbas
>> Thanks
>> the default field
>> common requirement.
>> Steve
>>> Hi Steve,
>>> in note. Hope this helps
>>> Thanks,
>>> Abbas
>>>> new default entry ?
>>>> so I could calculate a likely default by adding 1. How can I get that value
I don't think there is an easy and reliable way to forward values like
this. It might seem like you could use a calculate to forward the
value from question 1 to question 2, but any edits you make in
question 2 will likely be overwritten by the values in question 1 when
the form's data model is updated.
Steve
Thank,
Abbas
the default field
common requirement.
Steve
Abbas
new default entry ?
