I can not input number with more than 9 digits in the ODK collect questionnaire (form).
Using excel and then XLS form to convert excel file in xml type
I have searched in ODK related web pages without success
Looked for manuals in the web
I need to input identification numbers with 17 spaces (including number and hyphens). Though, xlsform only allows to input 9 digits. How can I increase the number of digits in a response and also how can I set the format to inclue "-" (hyphens)? Thank you very much in advance for your kind support. For example I need to input taxpayer identification number: 0614-010580-002-5 and need to use this format to avoid errors during filling the form in the field.
