I'm installing ODK locally in a linux machine (Ubuntu 12.04, tomcat 7, java
1.7/1.6 ) using the windows installer (through ODKAggregate.war). But when
I start the application through Tomcat Application Manager the following
error shows up:
FAIL - Application at context path /ODKAggregate could not be started
FAIL - Encountered exception org.apache.catalina.LifecycleException: Failed to start component [StandardEngine[Catalina].StandardHost[localhost].StandardContext[/ODKAggregate]]
It seems it is related with the Java version. Thats why I updated from 1.6 to 1.7 but the error remains the same.
My java:
$ java -version
java version "1.7.0_65"
OpenJDK Runtime Environment (IcedTea 2.5.3) (7u71-2.5.3-0ubuntu0.12.04.1)
OpenJDK 64-Bit Server VM (build 24.65-b04, mixed mode)
Nov 18, 2014 8:42:03 PM org.apache.catalina.core.ApplicationContext log
INFO: HTMLManager: start: Starting web application '/ODKAggregate'
Nov 18, 2014 8:42:07 PM org.apache.catalina.core.ApplicationContext log SEVERE: FAIL - Application at context path /ODKAggregate could not be
started org.apache.catalina.LifecycleException: Failed to start component
at
org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:154)
at
org.apache.catalina.manager.ManagerServlet.start(ManagerServlet.java:1247)
at
org.apache.catalina.manager.HTMLManagerServlet.start(HTMLManagerServlet.java:747)
at
org.apache.catalina.manager.HTMLManagerServlet.doPost(HTMLManagerServlet.java:222)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:641)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:722)
at
org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:305)
at
org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:210)
at
org.apache.catalina.filters.CsrfPreventionFilter.doFilter(CsrfPreventionFilter.java:194)
at
org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:243)
at
at
org.apache.catalina.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:108)
at
at
at
org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:224)
at
org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:169)
at
org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:581)
at
org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:168)
at
org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:98)
at
org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:927)
at
org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:118)
at
org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:407)
at
org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:987)
at
org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:579)
at
org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:307)
at
java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1146)
at
java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
at java.lang.Thread.run(Thread.java:701) Caused by: java.lang.UnsupportedClassVersionError:
com/google/apphosting/utils/remoteapi/RemoteApiServlet : Unsupported
major.minor version 51.0 (unable to load class
com.google.apphosting.utils.remoteapi.RemoteApiServlet)
at
org.apache.catalina.loader.WebappClassLoader.findClassInternal(WebappClassLoader.java:2840)
at
org.apache.catalina.loader.WebappClassLoader.findClass(WebappClassLoader.java:1160)
at
org.apache.catalina.loader.WebappClassLoader.loadClass(WebappClassLoader.java:1668)
at
org.apache.catalina.loader.WebappClassLoader.loadClass(WebappClassLoader.java:1546)
at
org.apache.catalina.startup.WebAnnotationSet.loadApplicationServletAnnotations(WebAnnotationSet.java:108)
at
org.apache.catalina.startup.WebAnnotationSet.loadApplicationAnnotations(WebAnnotationSet.java:58)
at
org.apache.catalina.startup.ContextConfig.applicationAnnotationsConfig(ContextConfig.java:381)
at
org.apache.catalina.startup.ContextConfig.configureStart(ContextConfig.java:858)
at
org.apache.catalina.startup.ContextConfig.lifecycleEvent(ContextConfig.java:345)
at
org.apache.catalina.util.LifecycleSupport.fireLifecycleEvent(LifecycleSupport.java:119)
at
org.apache.catalina.util.LifecycleBase.fireLifecycleEvent(LifecycleBase.java:90)
at
org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5161)
at
org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:150)
... 27 more
Correct. Your Tomcat instance is not seeing the proper java version.
On one of our Linux boxes, we needed to edit
/usr/share/tomcat7/bin/catalina.sh to set the proper JAVA_HOME
e.g.,
Once you make the change in that file, you need to stop and restart tomcat
to get the change to be detected and applied.
On Tue, Nov 18, 2014 at 12:13 PM, El Piqo wrote:
Hi there,
java 1.7/1.6 ) using the windows installer (through ODKAggregate.war). But
when I start the application through Tomcat Application Manager the
following error shows up:
My java:
$ java -version
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
... 27 more
I installed odk on tomcat 8 server and mysql server 5.7 but this what is
resulting to HTTP Status 404 - /ODKAggregate/Aggregate.html
can some one help out?
and l cannot access my tomcat application manager page
Ooops. I'm a bit late. I uninstalled tomcat7 and downgraded to tomcat6
since tomcat7 was not supported. Now when I deploy the WAR through tomcat
app manager, it uploads the file and says OK. I restart tomcat6 and I see
that next to the WAR is the ODKAggregate directory created but I dont see
ODKAggregate on the applications list of tomcat in order to start it.
Accessing: http://localhost:8080/ODKAggregate throws an HTTP 503, this
application is not available.
I'll keep investigating but if some one knows what could it be, or how to
troubleshoot it, hit me..
piqoni
> e.g.,
> http://stackoverflow.com/questions/11000497/how-to-configure-tomcat-to-use-java-7
> On Tue, Nov 18, 2014 at 12:13 PM, El Piqo <piq...@gmail.com > wrote:
>> Hi there,
>> My java:
>> $ java -version
>> I suspect it is related with this issue: https://code.google.com/p/opendatakit/issues/detail?id=1000
>> Below are the logs from Catalina:
>> *SEVERE: FAIL - Application at context path /ODKAggregate could not be
>> started*
>> *org.apache.catalina.LifecycleException: Failed to start component
>> [StandardEngine[Catalina].StandardHost[localhost].StandardContext[/ODKAggregate]]*
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> *Caused by: java.lang.UnsupportedClassVersionError:
>> com.google.apphosting.utils.remoteapi.RemoteApiServlet)*
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> ... 27 more
>> Regards,
>> Piqo
>> "ODK Community" group.
> Mitch Sundt
> Software Engineer
> University of Washington
> mitche...@gmail.com
Note that you need to manually download and copy the MySQL Connector/J to
the tomcat libs folder.
And you need to run the create_db_and_user.sql script.
I assume you are installing ODK Aggregate 1.4.13, and not an earlier
software release. Earlier versions are not supported on Tomcat 8.
Thank you Mitch, It is now fixed by setting my 1.7 java dirs at the JDK_DIRS
variable at /etc/init.d/tomcat6
Take care,
piqo
piqoni
On one of our Linux boxes, we needed to edit /usr/share/tomcat7/bin/catalina.sh
tomcat to get the change to be detected and applied.
On Tue, Nov 18, 2014 at 12:13 PM, El Piqo piq...@gmail.com wrote:
Hi there,
My java:
$ java -version
at org.apache.catalina.util.LifecycleBase.start(
at org.apache.catalina.manager.ManagerServlet.start(
at org.apache.catalina.manager.HTMLManagerServlet.start(
at org.apache.catalina.manager.HTMLManagerServlet.doPost(
at org.apache.catalina.core.ApplicationFilterChain.
at org.apache.catalina.core.ApplicationFilterChain.doFilter(
at org.apache.catalina.filters.CsrfPreventionFilter.doFilter(
at org.apache.catalina.filters.SetCharacterEncodingFilter.
at org.apache.catalina.core.StandardWrapperValve.invoke(
at org.apache.catalina.core.StandardContextValve.invoke(
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(
at org.apache.catalina.core.StandardHostValve.invoke(
at org.apache.catalina.valves.ErrorReportValve.invoke(
at org.apache.catalina.valves.AccessLogValve.invoke(
at org.apache.catalina.core.StandardEngineValve.invoke(
at org.apache.catalina.connector.CoyoteAdapter.service(
at org.apache.coyote.http11.AbstractHttp11Processor.process(
at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.
at org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.
at java.util.concurrent.ThreadPoolExecutor.runWorker(
at java.util.concurrent.ThreadPoolExecutor$Worker.run(
at org.apache.catalina.loader.WebappClassLoader.
at org.apache.catalina.loader.WebappClassLoader.findClass(
at org.apache.catalina.loader.WebappClassLoader.loadClass(
at org.apache.catalina.startup.WebAnnotationSet.
at org.apache.catalina.startup.ContextConfig.
at org.apache.catalina.startup.ContextConfig.configureStart(
at org.apache.catalina.startup.ContextConfig.lifecycleEvent(
at org.apache.catalina.util.LifecycleSupport.fireLifecycleEvent(
at org.apache.catalina.util.LifecycleBase.fireLifecycleEvent(
at org.apache.catalina.core.StandardContext.startInternal(
... 27 more
Groups "ODK Community" group.
On Mon, Mar 20, 2017 at 6:54 AM, Richard Ekpene wrote:
> Thanks, my odk aggregate is running on my tomcat server 8. but cannot find
> where my form is so l can upload to my server. how do l go about it?
> On Mon, Mar 13, 2017 at 6:07 PM, Mitch Sundt wrote:
>> See the instructions here
>> https://opendatakit.org/use/aggregate/tomcat-install/
>>> resulting to
>>> Post: opendatakit@googlegroups.com
>>> Unsubscribe: opendatakit+unsubscribe@googlegroups.com
>>> email to opendatakit+unsubscribe@googlegroups.com.
>> Mitch Sundt
>> Software Engineer
>> mitchellsundt@gmail.com
>> You received this message because you are subscribed to a topic in the
>> Google Groups "ODK Community" group.
>> To unsubscribe from this topic, visit
>> https://groups.google.com/d/topic/opendatakit/C_cbr6OdLV8/unsubscribe.
>> To unsubscribe from this group and all its topics, send an email to
