I have successfully used prompt type "image" with appearance "signature" in
ODK Collect. I am now trying to reproduce this with ODK Survey. Is this
appearance feature supported in ODK survey? I am designing the form in
Excel and successfully deploying the form in ODK survey after converting
with XLXSCoverter to a JSON form. When I reach this point in the form, I
just get the normal image capture prompt.
Thanks in advance
We have not had a chance to update Survey with all of the widgets available
in Collect -- for now, this feature is not available.
On Thu, Jan 21, 2016 at 11:41 AM, Paul Storry wrote:I have successfully used prompt type "image" with appearance "signature"
in ODK Collect. I am now trying to reproduce this with ODK Survey. Is this
Thanks in advance--
Hi Paul, i want to use "gather signature" in my form for collector on field. Can you help me? How did you do this?
El jueves, 21 de enero de 2016, 14:41:40 (UTC-5), Paul Storry escribió: > I have successfully used prompt type "image" with appearance "signature" in ODK Collect. I am now trying to reproduce this with ODK Survey. Is this appearance feature supported in ODK survey? I am designing the form in Excel and successfully deploying the form in ODK survey after converting with XLXSCoverter to a JSON form. When I reach this point in the form, I just get the normal image capture prompt. > Thanks in advanceHi there,
Use an image data type with an appearance of signature.
http://xlsform.org/ref-table/
You can see an example and the XML at
https://opendatakit.org/help/form-design/examples/#image_prompts
On Wed, Mar 15, 2017 at 10:50 AM, wrote: > El jueves, 21 de enero de 2016, 14:41:40 (UTC-5), Paul Storry escribió: >> I have successfully used prompt type "image" with appearance "signature" in ODK Collect. I am now trying to reproduce this with ODK Survey. Is this appearance feature supported in ODK survey? I am designing the form in Excel and successfully deploying the form in ODK survey after converting with XLXSCoverter to a JSON form. When I reach this point in the form, I just get the normal image capture prompt. >> Thanks in advance > > Hi Paul, i want to use "gather signature" in my form for collector on field. Can you help me? How did you do this? > > -- > -- > Post: opendatakit@googlegroups.com > Unsubscribe: opendatakit+unsubscribe@googlegroups.com > Options: http://groups.google.com/group/opendatakit?hl=en > > --- > You received this message because you are subscribed to the Google Groups "ODK Community" group. > To unsubscribe from this group and stop receiving emails from it, send an email to opendatakit+unsubscribe@googlegroups.com. > For more options, visit https://groups.google.com/d/optout.To be clear, the signature option is available in ODK Collect, but not
in ODK Survey.
On Sun, Mar 19, 2017 at 1:08 PM, Yaw Anokwa wrote: > Hi there, > > Use an image data type with an appearance of signature. > http://xlsform.org/ref-table/ > > You can see an example and the XML at > https://opendatakit.org/help/form-design/examples/#image_prompts > > Yaw > > On Wed, Mar 15, 2017 at 10:50 AM, wrote: >> El jueves, 21 de enero de 2016, 14:41:40 (UTC-5), Paul Storry escribió: >>> I have successfully used prompt type "image" with appearance "signature" in ODK Collect. I am now trying to reproduce this with ODK Survey. Is this appearance feature supported in ODK survey? I am designing the form in Excel and successfully deploying the form in ODK survey after converting with XLXSCoverter to a JSON form. When I reach this point in the form, I just get the normal image capture prompt. >>> Thanks in advance >> >> Hi Paul, i want to use "gather signature" in my form for collector on field. Can you help me? How did you do this? >> >> -- >> -- >> Post: opendatakit@googlegroups.com >> Unsubscribe: opendatakit+unsubscribe@googlegroups.com >> Options: http://groups.google.com/group/opendatakit?hl=en >> >> --- >> You received this message because you are subscribed to the Google Groups "ODK Community" group. >> To unsubscribe from this group and stop receiving emails from it, send an email to opendatakit+unsubscribe@googlegroups.com. >> For more options, visit https://groups.google.com/d/optout.Actually, the signature widget was added into ODK Survey in October 2016.
You can see an example of this in the app-designer repo. If you clone the
app-designer repo, an example form can be found at
app/config/tables/sign/forms/sign/sign.xlsx. I've also attached this file
for convenience.
Clarice
sign.xlsx (10.4 KB)
On Sun, Mar 19, 2017 at 12:46 PM, Yaw Anokwa wrote:To be clear, the signature option is available in ODK Collect, but not
in ODK Survey.On Sun, Mar 19, 2017 at 1:08 PM, Yaw Anokwa yanokwa@nafundi.com wrote:
Hi there,
http://xlsform.org/ref-table/You can see an example and the XML at
https://opendatakit.org/help/form-design/examples/#image_promptsYaw
form, I just get the normal image capture prompt.Thanks in advance
field. Can you help me? How did you do this?--
Groups "ODK Community" group.To unsubscribe from this group and stop receiving emails from it, send
an email to opendatakit+unsubscribe@googlegroups.com.For more options, visit https://groups.google.com/d/optout.
