I have a question related to skip patterns. I'll use the likes_pizza
example from the website (http://opendatakit.org/help/form-design/xlsform/)
as a reference.
Is it possible to include logic on the likes_pizza question instead of
programming it into the following question? For my survey, questions with
multiple responses give multiple skip patterns. For example, 1 goes to the
next question but 2 skips to the next section and 3 skips to the end of the
survey.
Thanks!
Kalee
Hi Kalee,
Selected is already a logic function and return true or false
So, Yes you can for example display the next questions with this logic
selected(${likes_pizza}, ‘1’)
Then the next section for selected(${likes_pizza}, ‘1’) or
selected(${likes_pizza}, ‘2’) more or less equal to
not(selected(${likes_pizza}, ‘3’))
Clement
On Wednesday, June 5, 2013 4:07:48 AM UTC+7, Katharine Lee McFadden wrote:
> Hi,
> as a reference.
> survey.
> Thanks!
> Kalee
Hi Kalee,
Thinking of branching as skips ends up making form design more
confusing. ODK doesn't have skips. It has relevance. That is, a prompt
will be show to the user if it's relevant. So if you want a prompt to
show up when likes_pizza is 2, you put "selected(${likes_pizza}, ‘2’)"
as the relevance condition for that prompt.
On Tue, Jun 4, 2013 at 10:45 PM, Clément Péron peron.clem@gmail.com wrote:
Hi Kalee,
Clement
as a reference.
survey.
Thanks!
Kalee
