After adding/modifying a CSV file in ODK Central that has issues an error displays when trying to load an Enketo webform. The current error message states:
CSV column heading "" cannot be turned into a valid XML element
Here was a wild goose chase that ended with the realization that I was looking at the wrong CSV file.
Creating a more specific Error Dialogue when Enketo loads to indicate filename.CSV that is problematic instead of the current generic CSV error message. Something like:
filename.CSV column heading "" cannot be turned into a valid XML element
I'm not sure how to best handle multiple problematic CSVs, but including all of them would probably be helpful if that isn't too difficult. They could be joined with a separator like: "problem1.csv, problem2.csv, etc."
Original
New
