Hi Group
Is there any way I can have the images named using a variable inside the
form? Example, use a name of a building and then have each of the 3 images
named "$buildingname_front" , "$buildingname_side" etc?
Bash
Hi Group
Bash
Bashir,
You can use a calculate to store what you want the image named (e.g.,
during your analysis phase) but you cannot change the underlying filename
that Collect uses. That underlying filename has to be unique and that's why
it's named automatically.
On Wed, Aug 13, 2014 at 4:43 AM, Bashir Jahed bashir@radarmob.com wrote:
Hi Group
named “$buildingname_front” , “$buildingname_side” etc?Bash
<http://www.avast.com/>
This email is free from viruses and malware because avast! Antivirus
http://www.avast.com/ protection is active.--
Bashir,
You can use a calculate to store what you want the image named (e.g., during your analysis phase) but you cannot change the underlying filename that Collect uses. That underlying filename has to be unique and that's why it's named automatically.
Need ODK services? http://nafundi.com provides form design, server setup, professional support, and software development for ODK.Hi Group
Is there any way I can have the images named using a variable inside the form? Example, use a name of a building and then have each of the 3 images named “$buildingname_front” , “$buildingname_side” etc?
Bash
This email is free from viruses and malware because avast! Antivirus protection is active.
To unsubscribe from this group and stop receiving emails from it, send an email to opendatakit...@googlegroups.com.
Yawn,
I have the same question but in a different way.
I only have one image in the former and I want the file name to be the same as instance name. The instance name is unique so the media names will be unique in this case.
Thanks.
The answer is the same. You currently cannot change the underlying
If this is a feature you'd like added to Collect, please file an issue
at https://github.com/opendatakit/collect/issues/new describing why
the feature is needed.
