How can I Provide a user interface for incrementing or decrementing a value in ODK's xml?
Hi Andrea,
it seems the answer right now is: no at this time, BUT reading in the net i
fond this
https://groups.google.com/forum/#!msg/opendatakit/T2lwpswAIx0/4YAFoI6CiAQJ
where
Yaw (that for sure will read this mail) says taht thay have a slider range
selector...but this was a while ago... maybe they finished the widget....
At the moment, i think you already thought about it and if you don't have
thousands of possible values you can use a select_one to display a pretty
good value selection object... or, as some one said out there if you have
to select an integer starting from 1901 and til 2xxx... you can use the
year spinner odk as explained here....
https://opendatakit.org/help/form-design/examples/#date_prompts
Ciao
Angelo
El sáb., 20 feb. 2016 a las 20:46, escribió:How can I Provide a user interface for incrementing or decrementing a
value in ODK's xml?
Thanks--
