i have some problem with the spinner widget. When the spinner opens the
options are blank and you only see the option by touching and holding over
one.
Did someone experienced that with xls2xform? Im using a motorola milestone
2 (a953) running stock 2.2 android. The latest version disponible on my
operator.
Nathan told me that he cant reproduce the error using my xls.
So i tried to run the form on a virtual machine running android ICS and the
form runs smoothly. So the problem is on my phone.
Did you know if is some software configuration that is causing the problem?
im concerned that we end buying phones not "compatible" with odk.
testdespinner1.xml (2.39 KB)
testdespinner1.xls (26.5 KB)
Guillermo,
What XLS2XForm converter are you using?
Matt
one.
operator.
the form runs smoothly. So the problem is on my phone.
im using the nathan develovpment version now. But with the
http://xls2xform.opendatakit.org/ Using the sample xls (that contains a
spinner widget) i get the same result.
Guillermo A. Perazzo
2012/2/29 Matt Berg
Guillermo,
Matt
one.
milestone 2 (a953) running stock 2.2 android. The latest version disponible
on my operator.
problem?
Guillermo,
I just tested it on formhub and it worked fine. Here the xform output.
I'm not sure if the xls2xform.opendatakit.org is running the newest version
of the xls2xform converter yet.
If you want to try using formhub, to get the xform click on other once the
form has been published and you should see the option to download the xform.
Matt
2012/2/29 Matt Berg mlberg@gmail.com
Guillermo,
Matt
one.
on my operator.
problem?
thanks matt but i have thesame problem. it seems the issue is with my phone
configuration. But i didnt know if it could get solved.
2012/2/29 Matt Berg
Guillermo,
version of the xls2xform converter yet.
Matt
Guillermo,
Matt
the options are blank and you only see the option by touching and holding
over one.
on my operator.
problem?
What happens if you run it on an Android 2.2 emulator?
> 2012/2/29 Matt Berg
>> Guillermo,
>> Thanks,
>> Matt
>>> 2012/2/29 Matt Berg
>>>> Guillermo,
>>>> Thanks,
>>>> Matt
>>>>> over one.
>>>>> on my operator.
>>>>> problem?
>>>>> Thanks
>>>>> Post: opendatakit@googlegroups.com
>>>>> Unsubscribe: opendatakit+unsubscribe@googlegroups.com
>>>>> Options: http://groups.google.com/group/opendatakit?hl=en
im downloadin the virtualbox image i will post this tonight.
2012/3/2 Yaw Anokwa
phone
Guillermo,
the
xform.
Matt
On Wed, Feb 29, 2012 at 3:00 PM, Guillermo Perazzo <gaperazzo@gmail.com wrote:
a
Guillermo,
Matt
On Wed, Feb 29, 2012 at 2:51 PM, Guillermo Perazzo < gaperazzo@gmail.com> wrote:
holding
over one.
disponible
on my operator.
and
problem?
Hi im posting the news of the spinner widget problem. It appears to be a
problem With the motorola milestone 2 froyo build.
I have tested the spinner on an android emulator 2.2 (SDK) and it works ok.
So it seems that the oficial rom of motorola has some kind of problem.
I atach an image of the emulator.
thanks To everyone.
2012/3/2 Guillermo Perazzo
2012/3/2 Yaw Anokwa yanokwa@gmail.com
phone
Guillermo,
the
xform.
Matt
On Wed, Feb 29, 2012 at 3:00 PM, Guillermo Perazzo < gaperazzo@gmail.com> wrote:
contains a
Guillermo,
Matt
holding
over one.
disponible
on my operator.
and
problem?
