I am also getting a similar error (SSL Peer Unverified Exception) when
connecting ODK Collect version 1.4.5 to Aggregate. I have installed a
certificate a .pk7 certificate (that bundled GoDaddy's intermediate and our
domain certificates) to the server but on testing using Networking4All and
SSLShopper I get the errors as shown on the attached images. I have tried
installing intediate certificates from GoDaddy available at https://certs.godaddy.com/repository as detailed http://technet.microsoft.com/en-us/library/cc754841.aspx. I believe I am a
missining a very tiny configuration or step to get this working and go and
celebrate. Can anybody please suggest a pathway/solution.
Tumaini, thanks for chiming in here. Could you name the server hostname and
the certificate issuer (e.g. Geotrust) in case the ODK folks need that info?
On 11 September 2013 02:24, Tumaini Kilimba wrote:
I have exactly the same message when trying to connect via ODKBriefcase
onto an SSL configured server... any help greatly appreciated.
and the certificate issuer (e.g. Geotrust) in case the ODK folks need that
info?
I have spent countless hours fixing this very problem for some of
Nafundi's clients. Here's what I think is happening...
Check your server certificate chain with SSL Shopper and you'll see
that the URLs that fail aren't chained to an old-school cert issuer
(usually Equifax).
Failure
Success
The reason those failed certificates work in the Android browser is
that browsers have lower levels of verification that match all
subdomains (usually called browser compatible hostname verification)
whereas I think Collect has stricter levels of verification due to the
default hostname verifiers of the HTTPS libraries it uses.
You can test this out by writing an app that uses different levels of
hostname verification. See
for an example.
Need ODK services? http://nafundi.com provides form design,
professional support, custom reporting, and software development for
ODK.
It did tend to be the case that everything on the device (including the
built-in browser) would fail to trust our certificate... so you're right
that your case seems different.
However, we haven't seen any indication of a problem in Collect's code.
Rather, if you Google "android SSLPeerUnverifiedException" you'll see lots
of other possibilities, including the one discussed here:
Christopher, thanks for your input. So far nobody has been able to explain
why the StartSSL and Geotrust certs are trusted by the Android browser and
pretty much everything else, but not by ODK. Does the ssl library consult a
different list of trusted authorities? Wouldn't that be odd?
We are using Android v4.x here, so age is not an issue.
I suspect there may be something slightly off with the SSL code in ODK.
Unless someone else has a clear explanation.
We use GeoTrust certificates for *.surveycto.com, and we have had trust
issues in the past -- never with Briefcase, but definitely with some older
Android devices. We spent enormous amounts of energy to make those issues go
away, including bundling our certificate with our build of Collect and
re-working the GeoTrust certificate chain to link back to a broadly-trusted
Equifax root authority. The latter solution seemed to be the key for more
ubiquitous trust, and I suspect that we could un-bundle our certificate
without any trouble. If you go to https://www.surveycto.com/support/login.html, you can see the certificate
chain we use. It was a huge pain to construct to begin with, and then it was
a huge pain to re-construct when we recently renewed.
Frankly, I would suggest giving up and just paying more for a Verisign
certificate that will likely be trusted by everybody out of the box. For us,
that wasn't an option because we're using a wildcard certificate, but for
one-off domains it's not worth the hassle to get a lower-priced certificate
to be as widely trusted.
Chris
info?
go away, including bundling our certificate with our build of Collect and
was a huge pain to re-construct when we recently renewed.
us, that wasn't an option because we're using a wildcard certificate, but
for one-off domains it's not worth the hassle to get a lower-priced
certificate to be as widely trusted.
Chris
info?
On 11 September 2013 09:10, Christopher Robert wrote:
Thomas, Tumaini,
Chris
info?
It could be a server configuration issue of some sort.
Chris
certificate chain we use. It was a huge pain to construct to begin with,
and then it was a huge pain to re-construct when we recently renewed.
Chris
info?
Hmm, that answer resulted in this: "After piles of digging and
experimentation, I finally realized that the url I was using had hard coded
port 80 instead of defaulting to 443. Dumb dumb dumb."
This is certainly not the case here.
Would love to hear the ODK core folks chime in on this one...
On 11 September 2013 09:55, Christopher Robert wrote:
Hi Thomas,
explain why the StartSSL and Geotrust certs are trusted by the Android
browser and pretty much everything else, but not by ODK. Does the ssl
library consult a different list of trusted authorities? Wouldn't that be
odd?
Chris
hostname and the certificate issuer (e.g. Geotrust) in case the ODK folks
need that info?
Bingo. Beautiful. I suspected something exactly like this. Thank you Yaw.
Is there any reason ODK's security level is so high? Higher than the
Android browser that is probably handling credit card information, etc.,
out the wazoo?
Or if there are some folks that need super high security, couldn't there be
a prefs setting? It could even default to super-high for all I care. Just
as long as there was some way to tone it down a bit.
I might could supply this patch if there was agreement...
On 11 September 2013 10:31, Yaw Anokwa wrote:
Tom,
(usually Equifax).
lots
explain
and
consult a
trust
older
issues go
broadly-trusted
more
certificate
it was
For us,
for
certificate
Chris
hostname
need that
info?
Is there any reason ODK's security level is so high? Higher than the Android
browser that is probably handling credit card information, etc., out the
wazoo?
a prefs setting? It could even default to super-high for all I care. Just as
(usually Equifax).
lots
explain
and
consult a
trust
older
issues go
broadly-trusted
more
certificate
certificate
it was
For us,
for
certificate
Chris
hostname
need that
info?
Android
wazoo?
be
Just as
(usually Equifax).
the
right
code.
lots
explain
browser
and
consult a
ODK.
trust
older
issues go
and
broadly-trusted
more
certificate
certificate
then
it was
Verisign
For us,
but
for
certificate
Chris
On Wed, Sep 11, 2013 at 7:53 AM, Tumaini Kilimba < tkilimba@ihi.or.tz> wrote:
hostname
need that
info?
It is all OK for our server but still SSLPeerUnverifiedException in
Briefcase.
Any update on Briefcase to lower the trust levels or to fix this?
Aurelio
Il giorno mercoledì 11 settembre 2013 16:31:53 UTC+2, Yaw Anokwa ha scritto:
> Tom,
> (usually Equifax).
> # Failure
> http://www.sslshopper.com/ssl-checker.html#hostname=https://elmo.sassafrastech.com
> http://www.sslshopper.com/ssl-checker.html#hostname=https://openhds.ihi.or.tz/ODKAggregateUrban
> # Success
> http://www.sslshopper.com/ssl-checker.html#hostname=https://www.surveycto.com
> http://www.sslshopper.com/ssl-checker.html#hostname=https://google.com
> http://stackoverflow.com/questions/2012497/accepting-a-certificate-for-https-on-android
> for an example.
> Yaw
> ODK.
> On Wed, Sep 11, 2013 at 6:55 AM, Christopher Robert <chrisl...@gmail.com > wrote:
> > Hi Thomas,
> lots
> http://stackoverflow.com/questions/11923380/android-ssl-javax-net-ssl-sslpeerunverifiedexception-no-peer-certificate-yet
> > Best,
> > Chris
> > On Wed, Sep 11, 2013 at 9:48 AM, Thomas Smyth <t...@sassafrastech.com > wrote:
> explain
> and
> consult a
> >> On 11 September 2013 09:10, Christopher Robert <cro...@surveycto.com > wrote:
> >>> Thomas, Tumaini,
> trust
> older
> issues go
> broadly-trusted
> more
> certificate
> certificate
> it was
> For us,
> for
> certificate
> >>> Best,
> >>> Chris
> >>> On Wed, Sep 11, 2013 at 7:53 AM, Tumaini Kilimba <tkil...@ihi.or.tz > wrote:
> >>>> Sure, server is https://openhds.ihi.or.tz/ODKAggregateUrban and the
> >>>> certificate issuer is Geotrust.
> >>>> Thanks again,
> >>>> Tumaini
> >>>> On Wed, Sep 11, 2013 at 2:48 PM, Thomas Smyth <t...@sassafrastech.com > wrote:
> hostname
> need that
> >>>>> info?
> >>>>> On 11 September 2013 02:24, Tumaini Kilimba <tkil...@ihi.or.tz > wrote:
> >>>>>> ODKBriefcase onto an SSL configured server... any help greatly
> appreciated.
> >>>>>> Tumaini
> >>>>>> On Wed, Sep 11, 2013 at 1:20 AM, Thomas Smyth < t...@sassafrastech.com > wrote:
> >>>>>>> Greetings.
> >>>>>>> In ODK Collect, when I try to connect to
> >>>>>>> https://elmo.sassafrastech.com (admin/temptemp), I get a
> >>>>>>> SSLPeerUnverifiedException, even though the certificate tests fine
> in tools
> >>>>>>> like http://www.digicert.com/help/?host=elmo.sassafrastech.com,
> and the page
> >>>>>>> loads fine in the Android browser.
> >>>>>>> Has anyone encountered anything like this?
> >>>>>>> It works fine for other servers.
> >>>>>>> It could perhaps be a caching issue. If someone else could try it
> on
> >>>>>>> their device, that would be a big help.
> >>>>>>> Tom Smyth
> >>>>>>> Worker-Owner, Sassafras Tech Collective
> >>>>>>> Specializing in innovative, usable tech for social change
> >>>>>>> sassafrastech.com
> >>>>>>> You received this message because you are subscribed to the Google
> >>>>>>> Groups "ODK Developers" group.
> >>>>>>> To unsubscribe from this group and stop receiving emails from it,
> >>>>>>> send an email to
> opendatakit-developers+unsubscribe@googlegroups.com .
> >>>>>>> For more options, visit https://groups.google.com/groups/opt_out.
> send
> >>>>>> an email to opendatakit-developers+unsubscribe@googlegroups.com
> >>>>> Tom Smyth
> >>>>> sassafrastech.com
> send
> send
> Groups
> >>> To unsubscribe from this group and stop receiving emails from it, send
> an
> >> Tom Smyth
> >> sassafrastech.com
> Groups
> an
> Groups
> an
Yaw.
Android
wazoo?
there be
Just as
(usually Equifax).
the
right
code.
lots
explain
browser
and
consult a
ODK.
trust
some
older
issues go
and
broadly-trusted
for
more
certificate
certificate
then
it was
Verisign
box.
For us,
but
for
certificate
Chris
hostname
need that
info?
Work with GoDaddy tech support to get to where you can connect to your
server from a wifi hotspot using an un-modified web browser on a client
computer (i.e., without installing or modifying the certificates on the
client computer).
Then Test with the browser on your Android device.
If those both work, then ODK Collect should work.
If you are installing new root certificates on the devices, something is
wrong with the issuer of the SSL certificate.
On Fri, Mar 20, 2015 at 5:33 AM, Tom Smyth wrote:
I'd recommend talking to GoDaddy support about this.
