Hi all,
I was wondering if the option to put a static marker on the middle of the map and move the map behind it, to set a location, has been reintroduced ?
Apparently there was a time when this was how you had to take the position on map, then it have been removed; but i heard recently that this is know an option again.
an example of this is the application NaturaList on playstore
thanks in advance
