Hi All,
I spent a lot of time reading all the ODK website info and troubleshooting
using this forum, and with help from the ODK team and info I managed to
complete the ODK workflow, from creating a form to downloading completed
forms into excel.
One of the major issues was that I have a form with lots of repeat loops,
which meant that ODK aggregate publisher was not usable to view or retrieve
my data. So I used ODK briefcase to generate a CSV file for each of my
repeat loops and then imported the CSV files in Excel and linked them.
During this process I made notes of the step by step instructions for each
leg in the process. Perhaps these notes will help others so I am posting
them here.
Please note I am not an ODK expert! I am just summarizing the steps that
worked for me that I have found from reading the ODK website and working
through my own form process.
I hope it helps:
Using ODK
Creating forms:
Design your form in Excel: guidelines & examples found at
https://opendatakit.org/use/xlsform/
Upload your XLS file to XLSForm:
a. Click “choose file” and navigate to where your XLS file is saved.
b. Click submit
c. If the form is correctly designed you will see two green buttons:
“Download” & “Preview in enketo”
Click “Preview in enketo”
This will open a new window for enketo
a. check the functions in your form are working (wont look identical to
the final form)
b. If there are issues, edit in Excel and repeat step 2.
c. When form is ready, close enketo window.
Click “Download” remember where you download to!
Uploading form to ODK Aggregate:
Log in to ODK Aggregate
https://your_url.appspot.com/Aggregate.html#management/forms///
(to set up an account see http://opendatakit.org/use/aggregate/
Upload XML to ODK aggregate
a. Click add new form
b. Navigate to where you saved your form in step 4 of previous section
Using forms
Download “ODK collect” app on an android device -
Enter app and in settings change the url and password to your
Aggregate url: https://your_url.appsport.com
Click “Get blank form” and save form to device -
Fill blank form and mark as finalised when complete -
Click “send finalized form’ and select forms you want to send to
your Aggregate site.
Retrieving data using ODK Briefcase
ODK aggregate publisher is not very easy to use when your form has several
repeat loops, so you can use ODK briefcase to create a final datasheet in
Excel with completed data from all your repeat loops.
View submissions in your ODK Aggregate account to make sure they
have arrived.
Download briefcase jar. and run it
Add aggregate URL: https://your-url.appspot.com
https://geoecology-bgu.appspot.com
Define where you want to store your briefcase download e.g
mydocuments/ODK briefcase
Enter Pull tab in briefcase jar. -
Select survey & click “Pull” data –wait until it tells you download
was a success
Enter Export tab- Export as CSV to directory ODK Export e.g
mydocuments/ODK Export
Open new Excel file in Excel -
Click Import Data/From Text -
Navigate to ODK export –CSV files (one for each repeat loop)
Select UTF-8
Select “ as delimiter
Repeat import for each repeat loop as separate excel sheet in your
workbok -
Identify the correct keys that link each repeat loop sheet to another
sheet and use the Vlookup function to create a final data sheet with all
your repeats.
