Sticky Top Percentage Progress Bar that Accounts for Skip Logic
What is the general goal of this feature?
We need a native, "sticky" percentage progress bar positioned at the top of the interface in both ODK Collect (mobile) and Web Forms (Enketo). Currently, there is no native way to pin a calculation to the top of a scrolling view without using field-list grouping layouts.
Crucially, this progress calculation needs to account for skip logic (relevance syntax). Instead of measuring strict question counts, the calculation engine should dynamically assess the denominator based on currently active/visible fields so the percentage value accurately reflects remaining work.
What are some example use cases for this feature?
  1. Long multi-page questionnaires: Enumerators frequently lose track of how close they are to completion, especially when jumping through deep thematic sections.
  2. Dynamic Skip Paths: If a respondent says "No" to a screening question that skips 50 subsequent questions, the progress bar should smoothly adjust its absolute target percentage rather than confusing the enumerator.
What is the potential impact of the feature?
  • Enumerator Morale & Speed: Keeps data collectors aware of time management during field surveys.
  • Form Cleanliness: Eliminates the need for form designers to write massive, convoluted calculate fields (${q1_status} + ${q2_status}...) and repeat manual progress indicators inside every question hint text.
