Storing data collector details in ODK
**1. What is the problem? Be very detailed.**i want to have data collector details stored in ODK like their names, Contact, Village Name, ID number, and sex whereby when he or she enters his ID number, the names and other information are filled automatically whenever they open a new form.
**2. What app or server are you using and on what device and operating system? Include version numbers.**Am using ODK Build and XLS form offline, ODK collect on google app engine
Sir, u have to use pulldata function for that detail of data collector stored in a CSV file
If one fieldworker use always the same device you could configure in Collect the UserName (that could be the userId), the mobile phone and the email of the fieldworker through the settings:
https://docs.opendatakit.org/collect-settings/#user-and-device-identity-settings
And the use this metadata in the form.
https://docs.opendatakit.org/form-question-types/?highlight=metadata#metadata
how do i do it, any sample CSV form and a pull data function?
They use different devices
https://opendatakit.org/help/form-design/data-preloading
http://xlsform.org/#how-to-pull-data-from-csv
pulldata.xls (332 KB)
SamplingRMC.csv (561.2 KB)
Try this one, pulldata function pull data from sampling csv and display on your screen
How is that one done for displaying on one screen
Sir, make a csv file names, Contact, Village Name, ID number, and sex with ID Number
then in your form give ID Number after that your form Display data collector names, Contact, Village Name, ID number, and sex etc.
Let me try this please, i will update you on the progress.Thank you
I AM SENDING YOU A FRESH SAMPLE TRY THAT ONE THEN YOU UNDERSTAND WHAT TO DOSampling.csv (164 Bytes)
pulldata.xls (189 KB)
I AM TRYING TO UPDATE MY CSV IN PULLDATA FUNCTION HOW CAN I DO THAT
I have created the CSV file called WeGo1 and my pull data form called WEGO FIELD QUESTIONARE-V7 and uploaded the CSV file to my android phone in odk,WEGO FIELD QUESTIONARE-Media folder.
When i try to enter the customer code, its not returning anything.
Attached is the CSV file and XLS form to review where am going wrong.WeGo1.csv (707 Bytes)
WEGO-SALES-FIELD-QUESTIONARE-V7.xlsx (13.6 KB)
anyone to help me please?
WEGO-SALES-FIELD-QUESTIONARE-V7.xlsx (14.0 KB)
try this one
