For reasons I wont go into here, I want to define a string value that
is ignored by the SCM. So I added a file to the res/values directory.
For example, I add a file res/values/foo.xml which contains:
<?xml version="1.0" encoding="utf-8"?>
Hello!
But when I do this and compile, the labels on the buttons on the main
menu are messed up, as if the wrong string resources are getting
assigned to them. e.g. the Manage Forms button now reads 'ODK Collect
v1.1.7RC1', etc.
Since the ...R class has numeric values for all the resources, it may just
be that the new file gets assigned numeric resources before the strings.xml
does and you need to clean and rebuild to update the old index values in the
compiled code.
In other UI frameworks (e.g., Windows), if there are multiple resource
files, you need to set a numeric baseline or offset value for the resources
in a file so that the framework can assign those resources (strings) the
values base, base+1, base+2, etc. and not reuse the values across files.
Never tried this on Android.
Hello!
v1.1.7RC1', etc.
On 19 August 2011 13:10, Mitch Sundt wrote:
> Have you tried to clean/build all ?
> compiled code.
> Mitch
>> Hello!
>> v1.1.7RC1', etc.
>> Anyone know why this might be happening?
> Mitch Sundt
> Software Engineer
> http://www.OpenDataKit.org
> University of Washington
> mitchellsundt@gmail.com
